ACE Reversable torque wrench??
Discussion in 'Camaro Questions' started by badazz81z28, Mar 19, 2010.
  1. 79camaro2001
    4,784
    May 4, 2003
    Monroeville, PA
    Sometime when I'm investigating a failure I tend to use the Torque wrench to check the torque on the bolts. If I suspect a blown head gasket I use the wrench to confirm the bolts was not loose, if it was then I probably don't have a problem with uneven surface of the head deck. But I still check the surface area for true flatness.
  2. bigblock665
    bigblock665 Veteran Member
    1,053
    Apr 7, 2009
    NY
    +1 If you set the torque and turn left on a left hand bolt it will tighten it to that specific torque and vise versa! its just like any other torque wrench just you can go both directions!
  3. badazz81z28
    21,034
    1,485
    Alabama
    I may just have to borrow or get another one. Even ACE doesnt even know...
  4. bigblock665
    1,053
    Apr 7, 2009
    NY
    Wow even ACE isnt sure?!?!?!:screwup:
  5. badazz81z28
    21,034
    1,485
    Alabama
    I know crazy huh...
  6. bigblock665
    1,053
    Apr 7, 2009
    NY
    Seems like they really know there own products! NOT!!!
  7. mmike
    mmike Member
    63
    Jun 7, 2008
    Aurora IL
    When checking Torque you should go in the tightening direction, starting lower and working your way higher, at correct torque it should be 5% higher then the value.
