AD244 alternator upgrade
Discussion in 'Electrical Systems' started by ULTM8Z, Aug 24, 2018.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,495
    603
    May 19, 2000
    Los Angeles
    Awesome!
    Upgraded to an AD244 alternator. Factory spec, AC Delco, 2002 Silverado. 130 amp.
    https://www.thirdgen.org/forums/electronics/755380-ad244-conversion-took-plunge.html
    The idle output is phenomenal. With everything on... A/C on high with auxilliary condenser fan, stereo, headlights, Taurus fan on high, and the EFI system itself, I'm getting 14.3V at the back of the alternator.
    My old CS130 would barely keep up... getting around 13.1V.
    And it looks cool to boot...
  2. Turbo70Camaro
    2,142
    117
    Jan 7, 2005
    so cal
    Direct bolt it?
  3. Twisted_Metal
    27,697
    1,307
    Can't see the third gen link without signing in.
    What wiring changes need to be made?
  4. ULTM8Z
    9,495
    603
    May 19, 2000
    Los Angeles
    Almost a direct bolt in. On the serpentine bracket mount, you have to elongate the mounting hole at the 9:00 position since the AD244 takes a 3/8" bolt as opposed to the 5/16" on the CS130. Except for that, it bolts right up
    For wiring, it's simply the main battery wire to the main output terminal. Then on the connector, it's the sense wire and a wire to the ignition circuit on the L terminal at the back of the alternator. Except on the wire to the L terminal, I have to put a 470 ohm resistor inline if you're not running the idiot light. If you're running the light, then I think you put the resistor in parallel with the light, such that if the light burns out, you still have the resistor protecting the alternator from full 12V exposure.
    And of course you have to get the pigtail connector for the AD244.
