adapter for power steering pump
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Layne02, May 26, 2019.
  1. Layne02
    Layne02 Veteran Member
    139
    Jun 25, 2013
    Georgia
    Have reman pump already in car and trying to get hoses all figured out and ordered but forgot about getting an adapter for back of pump. SO if I am using flared hoses, can anyone tell from picture which adapter I need for hose to connect to back of pump? Don't know pump year, probably bought it from Rockauto or somewhere long time ago, so what year it is ,is a mystery.
  2. dave@ztech
    [email protected] Veteran Member Lifetime Gold Member
    4,649
    1,070
    Mar 27, 2016
    NY
    just the typical o-ring to flare fittings
  3. Layne02
    139
    Jun 25, 2013
    Georgia
  4. Twisted_Metal
    29,894
    2,676
    Do you have your old pump?
    You can swap the fitting from it, if you do.
  5. Layne02
    139
    Jun 25, 2013
    Georgia
    No sir, there was no pump. But I am rethinking using the flare type hose. If that pump uses o ring, and I will be using an IROC box on it, wouldn't it be easier to just use hoses that take o ring? What year did they start using the o ring style fittings?
  6. CorkyE
    11,369
    902
  7. Twisted_Metal
    29,894
    2,676
    Camaros started with the metric o-ring seal in 80, if I remember correctly.
    My 78 had the old style but my 80 has the metric fitting.
  8. Layne02
    139
    Jun 25, 2013
    Georgia
    Ok, the car is an 80 that came with no motor, got a mid 80's motor for it, so hopefully thats what I ordered for. been so long my old mind cant remember. I will plug in fittings til something works, thanks
  9. dave@ztech
    4,649
    1,070
    Mar 27, 2016
    NY
    If you new power steer gear is for the 80 model then you will be all good as the hoses/lines will have the correct o-ring fittings and all will mate together.
