Adjust door hinges on an assembled car?
Discussion in 'Body Restoration' started by mrluckies, May 25, 2021.
  1. mrluckies
    mrluckies Veteran Member Lifetime Gold Member
    517
    57
    Dec 31, 2001
    NJ
    Does anyone have tips/info on adjusting door hinges on an assembled car? C302547E-EE21-4991-9069-40B0FA66BCFE.jpeg 67B751AF-FD82-4242-8BDD-CECA84A53CDE.jpeg I know there is a special wrench to loosen the bolts on the body to hinge bolts, but I need the door fully open to fit something and then I don’t have leverage to move the door. appreciate any advice, besides taking the front fender off!
  2. Scott51
    Scott51 Veteran Member
    740
    119
    Jan 2, 2012
    New Zealand
    Think of each bolt as a pivot point. Loosen the bolt you want to pivot on just a little so it’s still tight but not torqued. Back all the others off, when the door starts to separate from the hinge plate you’ve gone too far. Carefully close the door, push or pry it into position, open, tighten bolts, rinse and repeat.
    Requires lots of incremental adjustments and patience, and if the car’s never been apart you might have to fight the sticky caulking that GM sometimes put in between the body and hinges.
  3. CDesperado
    3,664
    98
    Oct 1, 2004
    Dallas Texas
    One thing that can help a lot is to get some 2x4s and build a small frame / jig that the door can rest on. You can use shims to help fine tune the alignment, but its a LOT easier when the door is resting on something, as opposed to trying to man-handle the door into the correct position.
  4. badazz81z28
    20,936
    1,470
    Alabama
    Why does the door need adjusting? Having the fender off is the best way.
  5. GoldenOne7710
    5,583
    854
    Jun 23, 2004
    Athens, GA
    The absolute best and easiest method is to have an extra person. 2 of us adjusted mine with nothing more that boxed end wrenches and a floor jack. One person kept the door upright while the other tightened bolts.
  6. CDesperado
    3,664
    98
    Oct 1, 2004
    Dallas Texas
    This is the longest, heaviest door ever produced by GM - getting it aligned properly with the fender and the body lines for the door gap (under the B-pillar and along the bottom rocker) is tricky. (But as the poster above mentioned, a floorjack and an extra pair of hands will help tremendously.)
    GoldenOne7710 likes this.
  7. badazz81z28
    20,936
    1,470
    Alabama
    No argument the door is big, but when the guts are not in it, it’s not hard. I did both my doors myself.
  8. mrluckies
    517
    57
    Dec 31, 2001
    NJ
    Thx guys! I’ll give it a try using a floor jack or something else. I also like scott51’s idea. Just didn’t know how to do it without dropping, but it seems reasonable.
  9. Scott51
    740
    119
    Jan 2, 2012
    New Zealand
    Rubber door wedges between the rocker and bottom edge of the door can also come in handy.
  10. Allison Winn
    Allison Winn Red70Z
    213
    30
    Jan 10, 2021
    Try hanging a Camaro door on a finished painted car! I built a custom dolly so I didn't chip the edges. You are welcome to borrow it if close - I am in NC. It is infinitely adjustable and on wheels 20200805_205522.jpg
    Revin likes this.
