{{ Afr Heads Sbc }}
Discussion in 'Swap Meet Section' started by slamdik, Oct 22, 2014.
  1. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    {{ Afr Heads Sbc }} ** HOWARDS ROLLER CAM KIT** VIDEO
    Set of used AFR 1035 195 street heads. These are the same as the 1036 but with no exhaust egr crossover.
    They have steam holes drilled in them so they will work with a 400 Chevy block but CAN be used with any other sbc.
    195 runners
    2.02 intake valves
    2.02 exhaust valves
    74 cc combustion chambers
    Comp 977 springs good for .655 lift
    $950 shipped to the lower 48
    Howards retro roller cam set up for small block Chevy
    Under 2k miles
    Howards billet roller cam with cast distributor gear.
    Howards Max Effort roller lifters
    Cloyes timing cover with cam button.
    Cloyes billet double roller adjustable timing chain with thrust washer
    Comp Cams fuel pump push rod
    $850 shipped to the lower 48
    Idle and little burn video
    http://youtu.be/IdxgeMYqeZQ
  2. franks70camaro
    franks70camaro Veteran Member
    903
    Jul 6, 2009
    fayetteville nc
    how old are the heads
  3. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    2003
    under 2500 miles
  4. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    Bump for added parts
  5. franks70camaro
    903
    Jul 6, 2009
    fayetteville nc
    how much for just the cam n lifters ????
  6. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    Offers?
    This is going on feebay soon if I don't get any action here.
  7. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    Why doesn't the title change on the swap meet page?
    I added the cam but it doesn't show up in the title.
  8. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Bump.
  9. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    Thank you
  10. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    Last bizzle
