After Market Control Arms
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by alan0043, Jan 28, 2021.
  1. alan0043
    alan0043 Member
    43
    Mar 26, 2008
    canton,ohio
  2. Bowtie7677
    Bowtie7677 Member
    60
    Jun 16, 2015
    RGV, TX
  3. bonedoc
    bonedoc Member Lifetime Gold Member
    74
    10
    May 8, 2017
    Arkansas
    Have a 1971 Camaro Z-28 Rally Sport. Changed over to Global West tubular upper and lower front control arms with Delrin bushings. Got 5.2 degrees of caster. Makes driving a "new" experience. Could not be more happy with these. Exceptionally well made. NOTE: they offer offset upper cross shafts to increase camber, running 0.5 degrees of negative camber. So if your tires are aligned now and your running a "ton" of shims, one should consider this option. You can order directly and tell them you want the offset shafts, no extra cost. At Summit Racing and Jegs, I never saw offset shafts as an option, so I ordered direct. Great customer service. My 2 cents
  4. 665 Almost Evil
    665 Almost Evil New Member
    Jan 19, 2021
    great post! and great information....
  5. VitoC
    VitoC New Member
    Dec 13, 2016
    I bought Global West upper control arms. Car handles fantastic. I have bought a number of products from them and their entire staff went out of their way when I called with questions or had to change to a different part. Great customer service and a great product
  6. VitoC
    VitoC New Member
    Dec 13, 2016
    Oops...Upper and lowers!!
  7. Mr Sunshine
    Mr Sunshine Veteran Member
    129
    17
    Dec 12, 2016
    Missouri
    I have purchased CPP (Custom Performance Products) upper and lower control arms. I know they are not at the top of the list with DSE and a few others, but I can tell you that the fabrication quality is very good. I've been in tubular/sheet metal fabrication my entire career so I know some about tube fabrication. But I will temper my enthusiasm because I haven't installed them yet so actual performance is still yet to be seen for me. Best bang for the buck? I can't say for sure, but it seemed like it at the time when I was doing the research as you are now. Just wanted to share my 2 cents. Attached photo is of the parts when I unpacked them. Look closely at the welds, fit, and finish etc.
  8. G72Zed
    G72Zed Veteran Member
    2,823
    1,329
    Sep 8, 2015
    I had the same experience, after looking over and installing the tubular upper/lower arms (coil overs) and going through the travel settings and motion ratios, I then quickly found out that the Caster/camber was still limited, I reverted back to the OEM lowers and SPC uppers with Delrin bushings.
    My alignment guy loves them, it takes no time/tools to adjust,(I actually do it now) no need to open the hood, no offset cross shafts and using or pilling shims in there, and you can get into the 7*-8 +caster range and 2-3 - neg camber with just a turn of the sleeves, quick"n"easy for track settings.
    BonzoHansen likes this.
  9. alan0043
    alan0043 Member
    43
    Mar 26, 2008
    canton,ohio
    Hi Everyone,
    I want to let you guys know that I am still reading and learning. Please keep the comments coming. I have been doing some reading in the engine section so I can get an idea of what motor I should run. But I will save questions about the engine for the engine section of the forum.
  10. biker
    biker Veteran Member
    3,461
    1,547
    Dec 7, 2014
    Same here, mine a great. Learning curve for my alignment guy, but huge improvement in ride and handling once set up.
