aftermarket distributor
Discussion in 'Engine Topic' started by CHEVYNICK58, Jul 1, 2016.
  1. CHEVYNICK58
    CHEVYNICK58 New Member
    23
    Nov 2, 2015
    spokane washington
    My ebay distributor is loose where it fits in the manifold,now what should i do?:confused: :confused:
  2. cbraswell
    cbraswell Veteran Member
    203
    Oct 7, 2010
    Dudley, GA
  3. Z28zz383
    Z28zz383 Veteran Member
    839
    15
    May 11, 2012
    Florida
    Does it have a cork gasket? Any plastic shims?
  4. CorkyE
    11,526
    974
    Your description is too vague, what do you mean by too loose? Is there sideways motion as if the diameter of the base not large enough, or like said above, not seating all the way?
  5. CHEVYNICK58
    23
    Nov 2, 2015
    spokane washington
    dist. loose sideways when down in-on manifold
    The dist. Loose , not like the stock dist.
