Aftermarket Electronic speedo calibration
Discussion in 'The BS Topic' started by Knuckle Dragger, Dec 4, 2021.
  1. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    How do you guys for it, just mark out the two mile interval or is their a GPS app I can't seem to find?
  2. biker
    biker Veteran Member
    4,329
    2,137
    Dec 7, 2014
    You MUST have access to either a mobile or stationary radar gun? That's the ultimate way to check. If using a stationary unit, you can still use it moving. If you use it stationary, make sure the radar is pointed dead nuts straight on relative to your path so as to avoid cosine error. (Or cosine "effect" as we have to say in court...prosecutors hate to use terms like "error" in relation to speed measurement technology...)
  3. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    I do not touch police stuff, that's their domain. LOL. To calibrate you need to drive 2 miles so it can get a signal count. Once it's set I can check accuracy with my GPS. I sure wish they would give you a data port do I could just enter my pulse per mile count.
  4. badazz81z28
    21,301
    1,540
    Alabama
    I find a somewhat straight away, drive my primary car to get the two mile mark. Then drive that path with the Camaro.
  5. biker
    4,329
    2,137
    Dec 7, 2014
    Ah. Ok, I get it.
  6. Bandit723
    Bandit723 Veteran Member
    3,818
    740
    Oct 1, 2016
    Waupaca WI
    I used a garmin gps unit when i calibrated my Dakota Digital setup. On my old Samsung phone it did have a gps app on it think it was called navigator deluxe.
  7. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    You just made me look at my Garmin unit again. It does look like it will count the miles for me. I didn't look in the right spot the first time through.
  8. BonzoHansen
    20,991
    1,931
    Jun 1, 2005
    Scott from Hamilton, NJ
    GPS....
  9. Knuckle Dragger
    16,629
    2,912
    Nov 2, 2002
    Waddell AZ
    That's what I ended up doing. I couldn't get my Garmin to count off the miles as I drove. Once done I confirmed I was good with the GPS MPH.
  10. GoldenOne7710
    5,637
    903
    Jun 23, 2004
    Athens, GA
    I mapped mine out with Google Maps. I then drove that route (made sure I ended in a big vacant parking lot) exactly 2 miles using my wife's car's trip meter. Got out and spray painted a line on the ground.
    Went back and got the Camaro and initiated the calibration mode, then drove that exact route and stopped at the painted line.
    I checked it on the way home with my phone GPS and it was spot on.
