Aftermarket Power Windows
Discussion in 'Interior Restoration' started by Detrailers, Mar 8, 2016.
  1. 71RS/SS396
    71RS/SS396 Veteran Member
    2,640
    43
    Aug 26, 2008
    Wake Forest NC
    http://www.nastyz28.com/forum/showthread.php?t=139323
    This is the best write up I've seen for adjusting the glass in these cars.
  2. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Correct, it's a full kit, there isn't a need to buy anything else (besides doing the relay upgrade). So you have to look at the TOTAL cost of the EL regulators PLUS wiring, which is around $400. But even then, they are not identical products. I am not bashing Electric Life by any means either, just saying I decided on SPW based on my own research of others' experiences with the product. I am sure both manufaturers' kits function great.
    One small aspect that also swayed me was the SPW products are US made by a small company. :)
  3. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    These are the two kits you'd need from CI to have a complete kit, unless you use another wiring kit. Factory wiring might even work if the plugs are the same as the GM motors.
    $290 for regulators/motors -- http://www.classicindustries.com/product/camaro/parts/fwk103.html
    $135 for wiring -- http://www.classicindustries.com/product/camaro/parts/swk100.html
    That's also before any discounts that are ALWAYS available. So assume 15-20% less than the combined $425.
  4. Detrailers
    Detrailers Veteran Member
    532
    21
    Sep 21, 2015
    Corinth TX
  5. Detrailers
    532
    21
    Sep 21, 2015
    Corinth TX
    So it's settled, junkyard is going to make my harness, and I'm going to buy regulators that work with it
  6. junkyardZ28find
    793
    9
    Mar 4, 2012
    des moines, iowa
    OEM wiring harness won't work with the late model window conversion kits-70-81 cars had the window motors grounded to the door shell-they are not reverse polarity motors.
  7. junkyardZ28find
    793
    9
    Mar 4, 2012
    des moines, iowa
    Thank you sir! You are going to have an easy time with this upgrade! And, you'll have an auto-down express feature ta boot for both doors!
  8. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    so you HAVE to use the corresponding wiring kits. good to know.
  9. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    dumb question - is it auto down only, or also auto up AND auto down?
  10. 2nd gen Guy
    2nd gen Guy Veteran Member
    612
    Jul 29, 2012
    Coon Rapids, Mn
    Not a dumb question
