Air cleaner over carb clearance
Discussion in 'Engine Topic' started by Blu-By-U 79Z, Nov 2, 2015.
  1. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,566
    24
    Feb 11, 2009
    Kentucky
    I know holley has the air horn that needs a certain amount of clearance. I was wondering if 1" of clearance above the choke of an edelbrock carb is enough.
  2. 80sz
    80sz Veteran Member
    3,928
    748
    Feb 2, 2014
    Buffalo,n.y.
    You're good
  3. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    I think general rule of thumb is at least an inch in order for the air to be able to enter the carb properly. At least that's the way I understand it. Seeing as how I've seen people only use a 1 inch filter total, I would think you're in good shape.
  4. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    matt, i have an edelbrock carb, an edelbrock drop base air unit, and an air filter. rim to rim lid to base is 3", this sits on stock motor mounts, a 350 sbc and edelbrock spreadbore rpm performer intake. this fits under a stock 79 Z28 hood the front face teardrop kind. mine has a screen underneath the hole, i dont know if that was stock or aftermarket. anyways the wingnut to hold the air filter down popped through the screen. i bought the drop base because i upgraded from the pro flow triangle of death, got it from jegs. its a chrome look with edelbrock script across the lid
  5. Blu-By-U 79Z
    5,566
    24
    Feb 11, 2009
    Kentucky
    Thanks guys
