Air cleaner too small, what should I do?
Discussion in 'Camaro Questions' started by rusty76, Apr 28, 2010.
  1. rusty76
    rusty76 Veteran Member
    267
    Apr 24, 2009
    Clarksville Tn
    With the new motor and intake I have in my 76 I dont have any clearance between the hood and the air cleaner and the tiny air cleaner is choking the motor pretty badly. I could cut a hole in the hood and cover it with a cowl but I was wondering if anyone had any other ideas. Thanks for the help.
  2. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
  3. Black78
    Black78 Member
    54
    Feb 15, 2010
    NY
  4. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    As suggested try a drop base.
    What intake are you using?
  5. Black78
    Black78 Member
    54
    Feb 15, 2010
    NY
    The dual intake setup is a pretty cool concept and id love to use it but if your going for nostagia then you want a drop filter with a paper element for sure (if itll fit)
  6. flowjoe
    8,047
    45
    Feb 7, 2006
    SoCal
    I just realized you have a big a$$ carb spacer in there - could take it out or use a shorter one to give you more options on air cleaner config. Just a thought
  7. rusty76
    267
    Apr 24, 2009
    Clarksville Tn
    Yeah, the spacer was because the the bore of the carb was different than the manifold. I like the dual filter setup. What company makes that? Ive tried a dropdown but it hit the linkage and fuel line.
  8. Steve's 74
    Steve's 74 Veteran Member Lifetime Gold Member
    2,750
    Dec 29, 2003
    Long Island, NY
    Be careful with the drop base. The one I have hit the e-choke housing, so I had to add a 1/2" spacer to raise it up a bit. But I'm now able to use a 14x3 filter and it just fits under the stock hood. (air gap mani and eddy carb)
  9. EricsZ28
    3,486
    Feb 28, 2006
    Here and there...
  10. rusty76
    267
    Apr 24, 2009
    Clarksville Tn
    Would that work since the carb is square bore and the manifold is spread bore?
