Alternator belt squealing 1970 Camaro
Discussion in 'Engine Topic' started by boltupal, Sep 9, 2021.
  1. boltupal
    boltupal Veteran Member
    183
    69
    May 21, 2018
    After changing my 70 from a TH350 to a 5 speed Tremec the alt. belt squeals. Ive checked and or replaced everything. The only way to stop it is removing the stock fan . Ive even tried different fan clutches. thumbnail_ATT00001 - 2021-09-09T145437.078.jpg thumbnail_ATT00001 - 2021-09-09T145500.096.jpg
    KingofThings likes this.
  2. Zspoiler
    Zspoiler Veteran Member
    4,064
    465
    May 6, 2012
    Federal Way, Washington
    What belts are you using I have a 377 inch small chevy with either a stock pulley set up or a March set up .I used a set Goodyear "cogged" belts up to 6500 rpm with no squealing,
    Zstar and KingofThings like this.
  3. xten
    xten Veteran Member
    4,333
    3,357
    Sep 24, 2014
    Pittsburgh, Pa.
    You didn't happen to paint in the groove of any of the pulleys, did you? I did and ruined brand new belts. Squealed like crazy.
  4. MChamp
    MChamp Veteran Member
    221
    61
    Jun 6, 2021
    north carolina
    you could try belt dressing, but I'd scuff the pulleys with scotcbrite. looks like your running an old pump pulley and a new alt. pulley. dunno if that would make a difference.
  5. Twisted_Metal
    29,962
    2,715
    That belt looks to be riding a bit deep in the alternator pulley.
    The tension comes from the sides of the belt.
    If the "V" bottoms out, it will be noisy.
    It could be a belt that's out of tolerance for width.
    (I bought a new belt once that did that and had to replace it.)
    Belt dressing will tell you which one is squealing but it's no cure.
    Spray a little on the suspect belt... if it stops squeaking when it's sprayed, you found the culprit.
    I've also used a bar of soap on the belt (while it's running) to find the squealer.
  6. tom3
    tom3 Veteran Member
    13,618
    1,138
    Aug 1, 1999
    ohio
    Sometimes you can scuff up the belt a bit and help this a lot. Idling just hold a wire brush against the belt sides, light pressure. And don't use a belt with a fabric type covering on the sides, those are for something that has to slip to start the driven pulley.
  7. boltupal
    183
    69
    May 21, 2018
    Thanks guys. While changing to a Dayco top cog belt I noticed the WP pulley has little wobble in it. Hopefully thats the culprit.
  8. KingofThings
    KingofThings Veteran Member
    382
    118
    May 8, 2020
    Let us know as that's what I was going to ask.
  9. manicmechanic
    manicmechanic Veteran Member Lifetime Gold Member
    2,148
    Oct 24, 2000
    Tulsa, Oklahoma
    Looking at the first picture. It looks like there is a slight alignment issue as the alt appears to be farther forward than the WP pulley.
  10. KingofThings
    382
    118
    May 8, 2020
    I was expecting that this was camera angle distortion as it didn't seem to be in the other photo. Phone cameras are great though they can distort things.
