Alternator breaking
Discussion in 'Electrical Systems' started by Thomas Mihalyi, Jan 14, 2020.
Tags:
  1. bnz433
    bnz433 New Member
    14
    Jan 2, 2020
    You really need to be doing some testing with a meter. Check your charging current and volts. But first, check all of your grounds, wiring continuity, etc. As mentioned above, if your belt is too tight, it will overload the bearing and cause a failure, so make sure you have it "just right"!
