Alternator requirement
Discussion in 'Electrical Systems' started by HULKZ28, May 28, 2015.
  1. HULKZ28
    HULKZ28 Veteran Member
    1,572
    Oct 15, 2005
    Jeffersonville NY USA
    I'm using an elec fuel pump and water pump on my new motor?is a single wire 100 amp alternator up to the task??thx in advance.
  2. bygblok
    bygblok Veteran Member
    770
    Nov 28, 2010
    Pensacola Florida
    depending on the amp draw of both it should be okay. Electric fans too? My CS130 runs my pump and fans with no problems and the fans draw a big load!
  3. junkyardZ28find
    793
    9
    Mar 4, 2012
    des moines, iowa
    Don't use a 1-wire. Stick with the GM 3-wire style but definitely convert to a CS design-they handle high loads much easier than the SI (stock) type.
  4. kimosabi
    kimosabi Veteran Member
    754
    Oct 7, 2013
    Not
    I "upgraded" to a 100amp SI style alternator from the stock DN, using the external reg to internal reg adapter plug from AAW and it sure does run hotter. It runs the dual fans, HEI, stereo etc ok but it's a little bit too hot for my liking. Next alternator will be a CS.
  5. Fbird
    5,431
    1,419
    Feb 12, 2011
    atlanta, ga
    ^^^ stick with the 3 wire system. MUCH more effecient than a single wire. YES they both work. Yes it will run stuff. yes 3 wires are more than 1.
    http://www.madelectrical.com/electrical-tech.shtml
    i'm pretty sure there aren't many folks willing/able to counter the "OLD GUY"..
  6. junkyardZ28find
    793
    9
    Mar 4, 2012
    des moines, iowa
    Lol....yes, Mark knows his stuff!
  7. HULKZ28
    1,572
    Oct 15, 2005
    what the difference between a cs and si alternator
  8. grzewnicki
    3,509
    220
    Dec 9, 2009
    Gordon from Jacksonville Fl
  9. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    i believe the CS alternators have higher amperage @ lower rpms.. so you don't get dim lights and stuff like that.. I used it on my previous motors and was happy with it.. Think I used it when I did the serpentine belt conversion using stock gm stuff off a 3rd gen camaro but bought the alternator new b/c it is a '96-up alternator.. IIRC.
  10. HULKZ28
    1,572
    Oct 15, 2005
    I went to summits site and find only alternators with the si style case..i have no idea what cs and si stand for..
