Am I being paranoid?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by mmike, Aug 6, 2009.
  1. mmike
    mmike Member
    63
    Jun 7, 2008
    Aurora IL
    I have a real nice “look like new” set of old Keystone rims. They are saluted for multi fit; I have new washers and lugs. I’m just worried about destroying them, as the car is 430 hp and 390 lbs. stall and shift kit. It tends to spin the wheels quite often.
  2. John Wright
    15,216
    401
    Aug 9, 2002
    Rustburg, Va
    The only keystones that I ever saw fail were front rims...(3.5 x 15's)
    Those would crack between the spokes.
  3. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    If you are spinning the tires you aren't putting that much torque to the parts. It's when the tires STICK that you break parts.
  4. mmike
    mmike Member
    63
    Jun 7, 2008
    Aurora IL
    cool I'll swap them around
  5. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    768
    Jun 22, 2005
    Wichita, KS, USA
    Please ensure you're using the proper lugs AND washers.
    I had a set of unilug Cragar S/S. I bought the proper long-shank lugs but used the thin flat washers that came with them. Turns out the lugs bottomed against the rear rotors before they tightened against the wheel, thus allowing small movements. Eventually the unilug slots wore large and the wheels were ruined. That's how I learned (from this forum) Cragar makes a thick tapered "centering washer". Installed those with the new set and haven't had an issue!
