And everyone told me BBC's Were Boat Anchors!!
Discussion in 'Competition Camaros' started by 79CamaroZ28, Sep 25, 2008.
  1. TooLateVTEC
    TooLateVTEC Veteran Member
    1,451
    Dec 5, 2005
    Fredericksburg,Va
    79Camaro, check Maliboosts sig...theres a perfect kit for you...wink wink.
  2. Maliboost
    Maliboost Veteran Member Lifetime Gold Member
    7,185
    May 18, 2001
    Maybe but........... I will NEVER be as old as "the old man". LOL. I hear he is slumbering happily in his rocking chair, wishing he had a big block for his Nova. ROFLMBO.
    Bob
  3. 79CamaroZ28
    79CamaroZ28 Veteran Member
    1,243
    Aug 1, 2001
    tucson, Arizona
    Bob and I have already talked about it. MUHAHAHAHAHA
    Gotta get my fuel system up to the task first, then ill spray the living he!! out of it!!
  4. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    You should have heard what he said when I told him I converted over to the Dark Side, LOL!!!
  5. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    Hey guys, need some info. The cam in this motor is only 254/268 at .050 and .613 .630 lift at .050 with 108LSA, It DOES NOT want to idle below 1300-1350 rpms, is this a problem? ive tried everything possible with this old 750 Dominator and cant get it any better or smoother. What do you recommend??
    Timing is 25 initial and 35 full, all in by 2,000 rpms... have a 6.5 pv in it right now and it smells rich, but wont idle at all if i turn screws in any more.. Power Valve blown??
  6. ZS10
    12,166
    Jan 18, 2003
    BC, Canada
    If the p/v was blown or opening from lack of vacuum, it would be so rich it won't idle, but the idle screws won't have any effect either, since the fuel is coming from the p/v.
    But...might want to check the vacuum and see if you need a lighter p/v.
  7. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    ok got it to idle finally, was a blown power valve!, Still wont idle below 1300 or so, I can put it in drive and it holds 1100-1050 or so but still wont hold its own idle in park or neutral below 1300. This cam is considered small isnt it?
  8. Maliboost
    7,185
    May 18, 2001
    I did, I heard it all the way over here on the coast. ROFLMBO.
    Bob
  9. Maliboost
    7,185
    May 18, 2001
    still smells like an intake leak. you have another carb to try on there??
    I guess Matty just had a vacuum leak in his intake manifold. thats a REAL toughie to find.
    Bob
  10. 79CamaroZ28
    1,243
    Aug 1, 2001
    tucson, Arizona
    Dont have another carb to try, wish I did.. All I want for christmas is a 900CFM pro systems and bobs nitrous shtuff.....:whine:
    On the other hand, i do have a 600CFM single inlet vacuum secondary but would be stupid to put it on, LOL...
