Another 421 Torque Monster AFR 1094-716 Heads
Discussion in 'High Performance Modifications' started by CNC BLOCKS, Nov 22, 2020.
  1. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,656
    30
    Oct 11, 2004
    NORTHEAST
    Another great day on the dyno, 421 the only difference from the last 421 is I used the AFR heads 1094-716 and I used a 1.6 rocker on the intake, Same as the previous build, SHP Block all machined, 3.875 stroke crank I did use the Callies Compstar 6.0 rods, Mahle pistons, Same cam 238/242 on 108 Lobe sep . Intake lift .611 Exhaust .573 Made 591 Torque at 4100 RPM and 555 horse at 5900 RPM, Same Carb, Intake, Dist. This engine only required 30 degrees of total timing, From where I started I was at 34 degrees of timing kept moving it back 30 Degrees was the best and went with a 34 high speed air bleeds. which gave me 14 more FT.LBS of torque
    and 20 more horse.
    Here Was the last build with the AFR 1036 heads
    https://nastyz28.com/threads/421-torque-monster.333043/
  2. Zstar
    Zstar Veteran Member
    2,105
    612
    Mar 23, 2014
    Ocala, Florida
    Great engine! And that is the color an sbc is supposed to be!!! LOL.
    CNC BLOCKS likes this.
  3. joel l voigt
    joel l voigt Member
    30
    31
    Oct 29, 2020
    That's a very stout engine!
  4. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    783
    45
    Aug 18, 2011
    Upstate New York
    This appears from my calculations to have been a very "honest" test. That is quite rare these days. Only about a 2% correction per J607 tells me the IAT was around 65F in the test cell.
    I have put "smallish" cams in engines that still produced very impressive numbers backed up by track performance at a later date. To me, that is a very potent street engine, that properly applied to a Camaro, would be low 11 performance at the track. Needless to say, I like your approach to a true street engine. Nice work.
  5. biker
    biker Veteran Member
    2,510
    976
    Dec 7, 2014
    Incredible numbers all in the right places for a street/strip motor. Looks great too.
  6. sandlapper
    sandlapper Veteran Member
    213
    57
    Oct 9, 2020
    SE CSA
    A good pan-tray unleashes power; seems that Champ is doing a good job as well
