Another 81 Camaro CP car
Discussion in 'Project Progress' started by Randy 81, May 6, 2010.
  1. Randy 81
    Randy 81 Veteran Member
    938
    20
    Oct 28, 2009
    Loganville, Ga
    Here are some picts of my 81 Camaro (originally 229 V6 base car) that I am making into a C-Prepared car, much like 1981paul is doing. It still in the early stages so don't expect much. I did trial fit the engine tonight to make sure the Moroso solid mounts lined up.
    Here is when I first got it home
    Here is the back side of the front bumper
    Now the engine in the car, no way a stock hood would fit.
    More to come later.
  2. ATM
    ATM Veteran Member Lifetime Gold Member
    2,268
    Oct 10, 2009
    Morris, Illinois
    I love the engine. You will be lucky if a cowl hood will fit. I think that there are cowl hoods that go all the way out towards the sides. Project is looking fairly solid too. Seems like someone has already put new bushings in it and at one time cleaned up the frame.
  3. frankz
    frankz Veteran Member
    2,128
    28
    Aug 24, 2009
    Illinois
    You made my day with the vacuum advance being connected!!!Is that an Offy manifold?
  4. Randy 81
    938
    20
    Oct 28, 2009
    Loganville, Ga
    I put Global West 1/2" drop bushings in and painted the subframe (after seem welding it up), I've had the car for 6 months (or more), but funds have been short. I had to get my El Camino running first. Now I should be able to start working on this car more.
    Yep, its the Offy intake, topped with Street HP 650 carbs. With 5" of vacuum at idle, I don't know how much the vacuum advance actually does, but it seems to prefer it hooked up.
  5. frankz
    2,128
    28
    Aug 24, 2009
    Illinois
    Randy,what are your plans for the chassis? Does the scca still require a .120 wall main hoop in your class?
  6. Randy 81
    938
    20
    Oct 28, 2009
    Loganville, Ga
    The car will get a full cage, I will be using 1-5/8" tubing which does have to be .120" min. I'm probably going to use a Comp Eng 12-point kit as a starting point and customize it as needed. I do have access to benders so I should be okay, already have the welder.
  7. Randy 81
    938
    20
    Oct 28, 2009
    Loganville, Ga
    Here are some picts of my El Camino which currently is my autocross car until the Camaro is done. The difference in hood clearance is amazing. The stock hood cleared the motor no problem, but no way it will clear in the Camaro. Also, the engine sits about 3-4" farther back in relation to the front wheels than the El Camino. That should help with handling.
    Here is my El Camino.
    Here is the 377 in place.
    Here is the 94 LT1 in place of the 377.
  8. brooksman9
    brooksman9 Veteran Member
    6,325
    321
    Jun 10, 2007
    Olive Branch, MS
    Nice. Very nice.
  9. Venom73
    Venom73 Veteran Member Lifetime Gold Member
    1,411
    Feb 4, 2007
    Louisville, Ky
    Very cool cars
  10. pokey_159
    pokey_159 Veteran Member
    496
    Nov 17, 2009
    St.Louis, MO
    cool dual carb motor set-up
    good luck with the maro
