Another engine bay wiring tidy up, photos please
Discussion in 'Electrical Systems' started by simso, Jan 2, 2021.
  1. Willie Bifulco
    Willie Bifulco Member
    58
    13
    Apr 13, 2020
    Steve...
    Starting to clean up my engine bay as well. I ordered spark plug wires that should have been the right length but sadly they were too long. I found a youtube video using zip ties to secure wires. The attached picture shows the end result. Basically you wrap all the wires together using one zip tie. Then you add three more zip ties between each of the wires. Slowly tighten down each of the ties until they're snug. It really does a good job of organizing long wires. See below the blue arrow in the pic. Good luck.
    younda and simso like this.
  2. procharged81
    procharged81 Member
    78
    19
    Nov 16, 2011
    NE PA
    You mean ceramic coat correct? Powder coat won’t hold up to the heat and will burn off. Most PC cures between 375-400 deg. Your headers are gonna get hotter than that.
  3. 73Motion
    73Motion Member
    36
    29
    Mar 1, 2016
    Corsicana TX
    I have to say I have been a member to the site for quite some time without posting. Just reading and listening to the fantastic information form so many experts with so much knowledge about anything Camaro. Great site! I would agree that running all wires I some sort of loom is key. Hide a much between fender well as possible. Also, plug wires are a big first sight item. They need to be very well thought out. Lots of options. I ran my a/c and alternator wires in small braided hose and placed between valve cover and intake. Very inconspicuous. About to install new big block, heater and a/c hoses will be behind fender as I have my hydroboost hoses now. Good luck. Added a few pics of new engine about to go in. ATTACH=full]110854[/ATTACH] BB3279D3-51FF-45C9-ABDD-97423FA76CC9.jpeg 2BEF5ADD-8E99-4935-BDD4-C0C36253185C.jpeg
    M1 Master Gunner and simso like this.
  4. simso
    simso Veteran Member
    592
    110
    Jul 10, 1999
    Australia Perth WA
    Apparently its high temp powder coat for headers, I genuinely do not know more than that
  5. EG1970-Z28
    EG1970-Z28 New Member
    Nov 28, 2019
    9EE254CF-E177-4D61-AB78-614D80FD34D1.jpeg 5310A754-2222-441F-AD6C-E9CF02B28598.jpeg F51D81F0-EE72-4B56-B65D-AEF772A20E1E.jpeg 2740796E-3FAA-4765-B8FB-003DFB5A9522.jpeg My latest build was a ‘79 Z28 350 CA car so there were harnesses running down both valve covers originally. I started out with a new M&H harness kit then lengthened both the alternator/charging harness (rh) and A/C & Temp harness (lh) down low on the engine and I also built a custom set of spark plug wires and ran them down low under the exhaust and up the back of the engine. I had to make it pass smog so I used a repro set of vacuum hoses with some tweaking and tidying them up where possible. Take some time and plan carefully and you’ll have a nice installation.
    simso likes this.
  6. simso
    592
    110
    Jul 10, 1999
    Australia Perth WA
    Like the colour of the rockers
  7. simso
    592
    110
    Jul 10, 1999
    Australia Perth WA
    hi temp powder coated, apparently rated to 630c
  8. procharged81
    procharged81 Member
    78
    19
    Nov 16, 2011
    NE PA
    I’m intrigued....
    I’m curious as to how they hold up. I’ve been doing PC for over 10 years now and never came across that.
    Keep me updated....
    simso likes this.
  9. 73 Z
    1,159
    73
    Jun 9, 2007
    Los Angeles, Ca
    Ran most wires through subframe, rad support, between fender & wheel well, and upper firewall. In my experiment running spark plug wires routed under headers seems better for longevity, heat rises and cracks wires under clamp system.
    383.jpg 1st spark plug wires.jpg 2nd plug wires left.jpg 2nd plug wires right.jpg
    simso and G72Zed like this.
  10. biker
    biker Veteran Member
    3,461
    1,547
    Dec 7, 2014
    Very nice.
