Antique Auto Battery - Sealed or Maintenence Free?
Discussion in 'Original Drivetrain Topic' started by Budz, Apr 9, 2020.
  1. Budz
    3,271
    307
    Mar 17, 2002
    Ashburn, Va USA
    Excuse the dirt...I've been driving it instead of showing the last few years... :lush::bowtie::bowtie:
    I haven't looked inside this battery in years, but recently it's become slow cranking so I took a look. What's going on here? The outer end cells appear to be refillable, while the center cells appear to have a smaller 'case' inside.
    Do you think I can refill the ends and charge it up, or is this a smaller 'sealed' battery enclosed inside the repro case?
  2. DB Z28
    DB Z28 Veteran Member
    645
    97
    Nov 30, 2003
    Fond Du Lac
    Fill it up with distilled water put a charge on it and give it a try nothing to lose
    70-camaro likes this.
  3. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    Buddy, I read that a lot of these batteries were made with small AGM batteries inside the reproduction case.
    Mike
  4. l16pilot
    2,027
    219
    Dec 13, 2004
    Hurlock, MD, USA
    ^^^ what Mike says. The Antique Auto reproduction batteries are only a molded outside case housing a smaller AGM battery. Filling the outer two caps will just fill the reproduction battery case and have nothing to do with replenishing the actual battery. What you see inside the middle four caps is just the top of the AGM battery.
    If your battery is getting weak, you can cut open the case and replace the AGM...but please do not fill the outer caps with water.
    Dave Nelson likes this.
  5. Budz
    3,271
    307
    Mar 17, 2002
    Ashburn, Va USA
    Thanks Mike, that's what it looks like.
  6. Budz
    3,271
    307
    Mar 17, 2002
    Ashburn, Va USA
    Got it, thanks. I guess I'm lucky it's lasted almost 10 years........
  7. Jim Streib
    Jim Streib https://www.flickr.com/photos/[email protected]/albums
    461
    89
    Apr 6, 2004
    Saint Louis, MO USA
    A buddy of mine gave me his old reproduction battery and cut it apart a week or so ago.
    From what I can tell, what was in this one is an Odyssey battery and going off of part numbers still on it could not find an exact replacement match.
    I still need to take measurements of the battery that was inside the case but if they still make a battery in that size, then one might be able to swap the guts out.
    https://www.flickr.com/photos/[email protected]/albums/72157713739408676
    While the below may not be a correct replacement, I will know more once I get measurements off of the internal battery I removed. Chances are it is an AGM non-spillable battery BUT it should never be used in an enclosed area like in a trunk as they still can vent explosive and corrosive fumes.
    Jim
    Budz likes this.
  8. Budz
    3,271
    307
    Mar 17, 2002
    Ashburn, Va USA
    ^^^ Thanks for the info and link
  9. 70 SS/L78
    2,911
    140
    May 5, 2005
    Rockford, MN
    AGM batteries cost more but they have more benefits. Longer life, not affected by cold temperatures as much, you can mount them sideways and tend to be more compact with same power output.
  10. fmarullo
    fmarullo Veteran Member
    406
    Mar 29, 2007
    Austin Texas
    Did you ever find a battery that will fit inside the vintage case?
