Any brick layers or masons? I need advice.
Discussion in 'The BS Topic' started by Shizzle, Aug 7, 2018.
  1. MotionClone
    MotionClone Veteran Member
    1,479
    303
    Jan 20, 2014
    away from the crazies
    Its not going to do much if you put a small piece of reinforce wire in but it may help hold things together and the stuff is pretty cheap.
  2. blown32
    blown32 Member Gold Member
    79
    Apr 21, 2010
    Prescott, Az
    There's a lot of window manufacturers that will build the window to any opening. If it's 3'2" x 2'8" they will charge you for a 4-0 x 3-0. You can always cut the sill to install a taller window, but the width could be a problem because of the lintel. We do this kind of work a lot, never an issue. If you order a masonry window frame it will come without the nailing fins. In stall the window and mortar it in place.
  3. Shizzle
    Shizzle Veteran Member
    2,801
    777
    Aug 1, 2012
    oak lawn, illinois
    I already have the windows that are pictured.
    I can’t cut the sill as it is a 8”x8” beam.
    The house was built in the 40’s, it doesn’t have a regular sill & rim joist like modern construction.
