Batman said:Have you contacted Weld to see what the finish is on the rims, i.e. coated, bare, etc? I'd start there and go accordingly.
Cuzz said:My "Weld Draglites" have a clear coat on them so I don't see how a aluminum polish will work.. If you have a clear coat on them I think you need something along the lines of a paint polisher unless you remove the clear coat and expose the aluminum..
David79Z28 said:My drag Lites aren't clear coated. Try a small amount of metal polish on them. If the applicator turns black then yours are not clear coated either.
If they are clear coated clean and polish them like the rest of the paint on your car.
muscl car said:So using a detail spray and microfiber towel will work ??
