Anyone have pics of there motor mounts with engine out??
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Aug 17, 2016.
  1. nobreaks254
    nobreaks254 Veteran Member
    517
    13
    Jul 14, 2007
    aberdeen, SD
  2. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
  3. giggity
    giggity Veteran Member
    1,503
    364
    Mar 18, 2013
    Pearland, texas
    heres a picture of my subframe when i pulled it out
  4. Twisted_Metal
    29,300
    2,262
    ^ There's only one place where mounts would fit on that frame.
    ^Nuts up... Smart move, IMO! ;)
    I put those AZ "Performance" mounts on first... :mad:
    Had to replace them with the "standard" mounts (engine side wouldn't line up) and it only took 20 minutes to do the swap since I put the nuts on top.
  5. 76_TypeLT
    6,394
    149
    Jul 26, 2008
    Houston, TX
    Either you or Bonzo suggested that and it made sense, so I did it ;) It worked out well.
  6. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,305
    307
    Dec 19, 2008
    Well looks like it is correct for location.
  7. QUAKE_WARS
    2,305
    307
    Dec 19, 2008
    Ok, so the Holley mounts dont work on my 80 due to the block hitting the ac box. Yes I even put a freakin hole in it. ( I did the install with no help). It puts the motor pretty high in the bay. I guess thats why their header fit so well:rolleyes: .. Motor sits pretty far back also. I will call holley tomorrow and see what they say. Im guessing If I had a non ac car it would be ok. Second, Its not possible to use a truck intake or front acc, with a stock hood. Camaro or T/A.
  8. QUAKE_WARS
    2,305
    307
    Dec 19, 2008
    Tearing it down for the test fit
  9. QUAKE_WARS
    2,305
    307
    Dec 19, 2008
    The truck exhaust would not work in the F-BODY either. I tried to drop it in with them on, but it was a no go.
  10. QUAKE_WARS
    2,305
    307
    Dec 19, 2008
    You can see here how it hits the A\C box :mad:
