Anyone install a car seat in a Gen 2
Discussion in 'Camaro Questions' started by Millwright, May 9, 2019.
  1. Millwright
    Millwright Member
    52
    22
    Mar 30, 2019
    Ontario Canada
    So I get it, a child carseat is not necessarily something you want to see in your camaro but I am buying it as something we can hopefully use as a family. Has anyone installed one in a gen 2 (specifically a 73)? I am going to need to put a forward facing seat in the back. The main seat belt should be fine but not sure what I can attached the upper anchor to. I want it to be safe and not have to make any permanent modifications to the car.
    I googled this a while back and didn't find much useful about putting child seats in classic cars. Lots of angry people raging on about how children shouldn't be put in classic cars. Lets not go that route.
  2. Lars_2Gen
    Lars_2Gen Veteran Member
    691
    213
    Dec 29, 2017
    Fullerton, CA
    Yeah, probably not much to attach the top anchor to without making modifications. You could probably use a u- bolt in the deck... but not sure how safe that would actually be...
    On the other hand, many kids rode safely in the back of many Camaros before the new safety regulations... just sayin.
    By the time my kids are riding in my Camaro they'll be able to sit in front.
  3. Millwright
    Millwright Member
    52
    22
    Mar 30, 2019
    Ontario Canada
    I'm ok with having to make a modification. I don't want to do something overly obvious that can't be removed.
    I use to ride on the parcel shelf in the back of my dads 63 Corvette when I was a kid (and I'm 35).
  4. RS1979
    3,973
    916
    Jun 18, 2013
    Memphis, TN
    When I first got my car, I bought some 3-point seat belts from SeatbeltPlanet.com. They were easy to put in the back seat and work flawlessly. They would work with your child seat.
  5. BonzoHansen
    20,279
    1,549
    Jun 1, 2005
    Scott from Hamilton, NJ
    For the seats that belt in I found the lap belts held those seats in way tight. I later added 3 points in the back when the kids moved to booster seats.
    If you have to use a latch system I guess you could run it through the reader deck and reinforce it underneath. Eventually you could take it out. new package trays are pretty cheap.
    Peck likes this.
  6. Peck
    Peck Veteran Member
    703
    228
    Mar 20, 2018
    Tacoma,WA
    My 1979 Camaro was my daily driver between the time my son was 2-6, a forward facing seat works just fine. As far as strapping it down I used the factory lap belt tightened down as tight as it could, his car seat never moved.
  7. Jeep43
    Jeep43 Veteran Member
    1,348
    53
    Mar 30, 1999
    Connecticut
    Agreed. I ended up buying a new aftermarket belt and buckle instead of using the vintage stuff.
  8. Millwright
    Millwright Member
    52
    22
    Mar 30, 2019
    Ontario Canada
    So I figured out my final solution. I picked up a car seat tether out of a GM pickup truck from the scrap yard. I was able to bolt it in behind the seat and the final product is pretty clean looking. Used a grade 8 bolt and heavy washer which will be stronger than the metal its attached to. Should be safe and I am happy with the end look. Also pretty easy to remove later on without any lasting reminders of it.
    dave@ztech and Peck like this.
  9. Tadunats
    Tadunats New Member
    Apr 15, 2020
    Which car seat did you end up going with? Sorry for being off topic.
    I've been doing a lot of research on car seats. I can see some people don't understand them when i've read a few reviews then I went and checked out blog reviews. Jeez it's just hype. You never get anything negative about the seats. Finally I've found a decent website which talks about evenflo everystage review and they actually mention the negatives. Do you have any advice which would help me.
