Anyone know about hot water heaters?
Discussion in 'The BS Topic' started by 76 camaro car 1, Mar 21, 2021.
  1. John Wright
    15,166
    385
    Aug 9, 2002
    Rustburg, Va
    Make sure that the water heater is actually full of water, and not just air, before you turn the power back on. Those elements won't last but a few seconds without being immersed in water. When you turn the valves back on to refill, go to the farthest hot water spigot away from the heater and open to let the air out and leave open until the gurgling stops and water flows without gurgling, then the water heater should be okay to turn the power back on.
  2. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,443
    29
    Apr 23, 2010
    St.Augustine,Florida
    Thanks to everyone who commented. I checked the elements with my multi meter and have continuity on both coils so I guess they are not my problem. Going to try flushing it when I get off work tomorrow and see what happens. Never knew water heaters needed cleaned out but when I think about it make perfect sense.
    kenny77 likes this.
  3. COPO
    20,537
    2,266
    If you have hard water, you s/b draining it once a yr. Calcium buildup is not good on the elements. If you never change your car coolant, it’ll be the same. White crap all over clogging the rad tube passages.
  4. GoldenOne7710
    5,474
    785
    Jun 23, 2004
    Athens, GA
    Continuity is one thing...but did you check the ohms?
  5. tom3
    tom3 Veteran Member
    13,316
    932
    Aug 1, 1999
    ohio
    Could be the thermostat on the controller. And most (all) heaters have a controller that only allows one element at a time to be on. Possible that the controller is not alternating the elements as needed.
  6. Lowend
    16,209
    1,144
    Mar 25, 1999
    San Jose, CA, USA
    Don't get freaked out by the chunks of stuff, there's gonna be a lot of them. It's just mineral build up
  7. wnmech
    wnmech Veteran Member
    1,261
    252
    Jul 20, 2014
    grand prairie tx.
    Maybe I’ve been lucky I installed my hot water heater back in2002 and have never drained it and knock on wood it still super heats my water. Electric water heaters are very simple it’s either the element or one of the thermostats. Did you disconnect both leads off of the elements before you homed them out?
  8. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    3,016
    210
    Jul 31, 2001
    Ft. Lauderdale, FL
    Did you disconnect the wires from the element before testing them?
    Is there power going into the t stat control above the element ? What about the reset button on the stat?
  9. kenny77
    3,016
    210
    Jul 31, 2001
    Ft. Lauderdale, FL
    Did you test the power going into the thing at the top. Do you have 220 ?
    If that dip tube or pick up tube or supply tube or whatever they call it is indeed rotted off inside there......you're done
  10. sandlapper
    sandlapper Veteran Member
    619
    200
    Oct 9, 2020
    SE CSA
    clamp-on ammeter will tattle as well; ya don't need a top brand for occasional home diy. $20 at HF will do it.
