Anyone know about hot water heaters?
Discussion in 'The BS Topic' started by 76 camaro car 1, Mar 21, 2021.
  1. roadrace2
    roadrace2 Veteran Member
    1,787
    117
    Jan 13, 2000
    Earth......?
    I just replaced my electric water heater - 40 gal tank. The old one was ready to burst at the seam - looked pregnant.....
    I install my own drain valves on all my heaters - to make it easy to flush. (pipe size is 3/4") I purchase a brass 2" nipple with a ball valve and a short nipple on the front of the valve so I can hook up a garden hose so I can drain the water into the nearby drain (which is code).
    With well water you would want to flush twice a year. I just did a flush on mine yesterday and it was freaking gross......one tell tale sign of needing a flush is that your hot water stinks like sulfur.
    Also, you may want to look into replacing the anode (if your tank is still salvageable).
    My 2 pennies.
