Anyone know how to get rid of squirrels
Discussion in 'The BS Topic' started by 76 camaro car 1, Jul 8, 2018.
  1. RS1979
    3,987
    924
    Jun 18, 2013
    Memphis, TN
    They do make a .22 Quiet ammo. The problem you could have is where the bullet would end up if you miss the squirrel
  2. 351maverick
    351maverick full time Ebay seller/hustler/car killer
    3,803
    532
    Aug 11, 2010
    erie, PA
    that stuff is FAR from quiet!
  3. NYH1
    NYH1 Veteran Member
    1,604
    12
    Feb 27, 2010
    Central New Yorkistan
    It's all about setting up your hide right. Shooting .22 quiet ammo from inside your house, through a slightly cracked open window makes all the difference in the world! ;)
    NYH1.
  4. GoldenOne7710
    5,380
    746
    Jun 23, 2004
    Athens, GA
    I shoot subsonic .22 shells fairly often. My pellet rifle is louder than those subsonic rounds.
    OP, it doesn't take a $200 pellet rifle to kill a squirrel. I've killed hundreds in my lifetime with this bb/pellet rifle. The secret is to pump it multiple times and use pointed pellets for penetration.
    https://www.academy.com/shop/pdp/daisy-model-880-powerline-air-rifle
  5. ProStreet383
    ProStreet383 Veteran Member
    2,106
    9
    May 23, 2007
    MD
    Pellet gun does the trick and mine is nearly silent.
  6. dcozzi
    dcozzi Veteran Member
    3,904
    963
    May 1, 2002
    Phoenix, AZ
    Get a Piece of 4" ABS drain pipe and lean slightly against the wall so a little light can be seen from the top. Place a piece of dog food at the bottom where it meets the concrete. They go down and cannot get back up. You can do whatever you want to with them after you trap them.
    NYH1 likes this.
  7. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,827
    130
    Aug 18, 2003
    On Wisconsin!
  8. rscamaro73
    rscamaro73 Administrator Staff Member
    14,972
    16
    May 30, 1999
    Striking fear and destroying the enemy
    My dad has been trapping and relocating the squirrels into a state forest off his property like 5 miles away.
    He hasn't run out of squirrels to trap in the last 5 plus years of doing it.
    You need feral cats. And hawks. Predators. They're on duty 24-7.....
