Anyone Running This Manifold??
Weiand Team-G 3/4" raised # 7532, I like the Holley Strip Dominator # 300-25 but it's too tall.
23,777
Gallatin Tennessee
Car Craft did a open plenum intake manifold test for their 7/13 magazine and the Team G was one of the intakes tested
on a 10.1:1 400sbc running TFS 215cc heads , crane solid roller "no specs given" and a 850 holey 4bbl test mule engine made 524hp @ 6200rpm , peak tq#'s of 507ft lbs @ 4600rpm and average tq #'s of 478.4
peak hp #'s it placed 15th out of 19th
average tq placed 16th out of 19th
average tq per dollar it placed 6th out of 19th
BigBlock 79Z
79
Des Moines, IA
I had a raised one on my small block. Back-to-back with a Victor Jr the G outperformed it. I have a raised Team G on my BBC and like it. The raised one makes more power than the low one Car Craft tested if you can fit it.
Lowend
Administrator. .a car, a man, a maraca.
16,759
San Jose, CA, USA
... and Car Craft invalidates their data in one fell swoop. I seriously hate it when magazines do stuff like that
23,777
Gallatin Tennessee
found the cam specs ...Crane solid roller cam
248 in / 256exh @ .050 630/630 lift 106LSA
I don't know why they didn't use this 3/4" raised 7532 or the 2" raised 7531 for their test?? a few of the intakes where on the tall side and performed the best.
I have a 406 build up I'm going to start and I'm trying to get my parts list together and I'm going back and forth be between SHP200s and Profiler195s which I want to use, but by builder has cnc programs for the Darts.
Also debating between the 282S Magnum solid and the XS274S extreme energy solid?
soco200p
374
Chicago burbs', Illinois
I agree, they should have included the others, but in car craft a little while back they included the higher versions, though for the SBF, and they performed a bit better at higher RPMS.
It's an "ok" intake which is mostly designed for those that want a single plane that will still fit under the hood.
79CamaroZ28
1,243
tucson, Arizona
There is much better cams out there then those two. The 282 is a older grind... Call straub technologies or bullet and give them your engine specs. They can provide you a cam that will be much better suited.
