auto darking welding helmet?
tims78camaro
608
louisville ky
i have never use one and im having trouble with it. my problem is it to dark when i weld and when the garage has all the light on it goes dark. can i turn sensitivity all the way down without it hurting my eyes just afraid i will set something to low
Gary S
24,783
That sounds to me like the helmet isn't working like it should. Mine will not darken under garage lighting unless I look directly into a very bright light. Your garage lighting shouldn't be enough to make it darken.
Crazy4camaro
498
Greenville SC
The sensitivity has nothing to do with the shade number, you should have a dial with numbers on it for the shade. If not you will have to change the dark lens out with a lighter one. Post a pic of your controls.
hogg
3,200
pegram,tn.,cheatam
maybe letting the lite get in behind you , try putting on ,over the back of you head,neck,a rag , so lite from over head don't get in. Maybe
SRGN
681
Central NJ
Almost forgot, make sure there isn't a "grind mode" switch that has been inadvertently switched on. It won't get dark enough if activated and may affect sensitivity as well.
tom3
15,336
ohio
On mine I think the grind mode is basically off. And do try different adjustments. These helmets are made to work with various welders, stick weld in thicker metal you'll have a big arc, mig in sheet metal much smaller. Pretty amazing device when it's working right though.
brooksman9
6,404
Olive Branch, MS
I believe OSHA standards are a setting of 13 or higher. We had some nice inexpensive Miller hoods at work that only went to either 11 or 12 and they were just not dark enough. You could tell after you had been welding for a bit. I did not like them. Bought some that went higher and they are much better.
