auto to 5 speed
Discussion in 'Transmission & Driveline Topics' started by joer, Oct 6, 2017.
  1. joer
    joer Veteran Member
    233
    Sep 25, 2008
    East Brunswick, New Jersey
    how to remove auto brake pedal assembly. What's the easiest way.
  2. czizza
    czizza Veteran Member
    1,075
    86
    Jan 8, 2004
    N. Massapequa, NY, USA
    I did not remove the whole assembly ... I removed the pivot bolt then removed the big auto pedal ... and replaced it with the two pedals from the manual setup + bushings and bolt ... The frame is the same.
    If you are going to go down the route of removing the assembly you need to pull the booster and part of the dash ... way too much work.
  3. rchydzik
    850
    25
    Nov 13, 1999
    Colbert, WA USA
    You will need to remove the lower dash. Removing the cluster really helps. +1 on removing the pivot bolt and not the whole assembly.
  4. joer
    joer Veteran Member
    233
    Sep 25, 2008
    When you say cluster. What exactly to you mean.
  5. czizza
    1,075
    86
    Jan 8, 2004
    I believe when he mentioned the cluster he was referring to the instrument cluster ... if you remove that you can see the top of the pedal assembly.
  6. joer
    joer Veteran Member
    233
    Sep 25, 2008
    Thank's I'll give it a try.
  7. camaro lover
    camaro lover Veteran Member
    463
    30
    Dec 29, 2002
    Owen Sound, Ont, Canada
    another vote for leaving the assembly in the car. just be prepared to squeeze into a tight spot to get at it. hope your a small framed guy like myself. wouldn't hurt to buy new plastic bushings that go on the pedal pivot bolt.. your old ones are probably toast. then you only need to get in there once and the bushings are cheap. nice ride by the way.
  8. joer
    joer Veteran Member
    233
    Sep 25, 2008
    I'm 6'1 200 pounds and 63 years old. No fun job. Took out the steering column. Pulled off the brake booster and took out the assembly under dash. Found a complete 4 speed assembly on E-Bay. As soon as it gets here back in business.
