Automatic question...
Discussion in 'Transmission & Driveline Topics' started by RockerMomsHotwheels, Sep 1, 2009.
  1. RockerMomsHotwheels
    RockerMomsHotwheels Veteran Member
    721
    Jan 14, 2007
    Our King's Ranch... Fredericksburg Texas
    Can anyone tell me if a TH350 from a 71 will fit in a 79...(Camaro)? I need to know if the cross member is the same...
  2. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
    Should bolt right in, if it had a th350 before.
    I believe only the th400 crossmember is different.
    -Rich-
  3. Twisted_Metal
    27,680
    1,300
    If it was pulled from another Camaro (or almost any passenger car) it will have the proper tail shaft/housing and will be a direct bolt-in job with the proper crossmember.
  4. RockerMomsHotwheels
    721
    Jan 14, 2007
    Yup, from a 71 Camaro to a 79 Camaro...
    I need to know the crossmember should be the same?
  5. warped
    3,212
    Oct 20, 2003
    Sitting in my command bunker waiting for the zombi
    there have been a few oddball TH350 models over the years, mostly in truck applications. since you are using a passenger car trans in a passenger car application, the cross member will be the same and fit without issue. Good luck.
  6. ezcruisn71
    ezcruisn71 Veteran Member
    239
    Jun 2, 2006
    SE, Michigan
    Yeah, the TH400 used a different crossmember.
