Chris Greenley
- Dec 15, 2020
- 93
Need to move back a half inch back to clear the exhaust do I just drill out the 3 dots grind spots and tack weld
it back in
Thanks will considerHave you considered switching to the bracket that bolts on using one of the rear cover bolts? Would give you more room for exhaust and you'd eliminate the bracket in your pic. Pic below is of a 12 bolt, but 10 bolt is similar, the bracket is just over a little bit. Lines in pic are set up for disc brakes so if you have drums you'd just run solid tubing to the wheel cylinders along the axle tube.
Need to move back a half inch back to clear the exhaust do I just drill out the 3 dots grind spots and tack weld View attachment 143491 it back in
