Axle end play solutions
Discussion in 'Transmission & Driveline Topics' started by AlbertaZ28, May 9, 2020.
  1. AlbertaZ28
    AlbertaZ28 Veteran Member
    299
    9
    Aug 17, 2010
    Fort Mcmurray, Alberta
    Looking for thoughts on reducing my axle end play for disc brakes. I realize the best way is to replace and shim my clutch pack, but I don’t want to put the money into this diff and they are hard to find for the stock LSD. It’s a stock 8.5” 10 Bolt with the stock limited slip differential. I might look at upgrading down the road.
    I am thinking about either shimming behind the C-Clip or making my own thicker c-clip. Right now I have .031” end play on the drivers side. I would like to get it down to between .005” to .010”. I have shims on order and think that might be the best way.
  2. Zulu28
    Zulu28 Veteran Member
    299
    26
    Dec 19, 2013
    Vancouver, BC
    That's what I'd try, that's the trouble with this style of diff, great with drum brakes but disks are a whole 'nother topic, I guess this is why the 9 inch is so popular, you could mod what you have but I think you'll find out that it's not cost effective, to bad really because the 8.5" is a good strong diff but with sloppy axles disk brakes back there takes on a whole new meaning.
  3. camaro71/holland
    1,525
    208
    Aug 27, 2003
    The Netherlands
  4. AlbertaZ28
    299
    9
    Aug 17, 2010
    C-Clip made and installed. Was able to get the end play down to .012" on both sides. I think I will take it.
  5. AlbertaZ28
    299
    9
    Aug 17, 2010
  6. djorgensen3
    djorgensen3 Veteran Member
    802
    170
    Oct 15, 2009
    Peoria, Az
    Yes. I wish I had seen this thread earlier. I went to that shop and bought some of the thicker c-clips. The owner is super nice. He offered to let me take a bunch home and try them until I found the right ones and just bring back the ones I didn't need and pay after the fact.
    mrfleet12 and Knuckle Dragger like this.
  7. Fbird
    5,807
    1,692
    Feb 12, 2011
    atlanta, ga
    I believe Randys also has thicker c-clips available
  8. AlbertaZ28
    299
    9
    Aug 17, 2010
    Thanks. I will check them out.
  9. AlbertaZ28
    299
    9
    Aug 17, 2010
    I did a bit more adjusting and got both sides to 0.007” end play with my custom made C-Clips. I think that’s the better way to go rather than trying the shims. Thanks for the suggestions.
