B&M Shifter cable length
Discussion in 'Transmission & Driveline Topics' started by nbfd7, May 23, 2020.
  1. nbfd7
    nbfd7 New Member
    May 11, 2020
    Can anyone recommend the correct b&m shifter cable length for a 73 camaro th400 with a console quick silver shifter?...I couldn't get the stock cable to work (I know it should work just fine) and Im done messing with it and im just going to order the b&m cable from summit.
  2. PBZ28
    PBZ28 Member
    71
    40
    Nov 3, 2017
    I’ve got the same set up in my 79. Used bracket and lever kit ( BMM-35498 ) and cable ( BMM-80605 ) from Summit. Both part numbers are B&M. The stock? lever and cable never did work very well on mine either. It was always to tight pulling down to first gear. Works just fine now. Hope this helps.
  3. nbfd7
    nbfd7 New Member
    May 11, 2020
    thanks for the input...I ordered the 4 foot cable..hope it works just fine...I also ordered the b&m trans cable bracket and gear selector lever...hoping these take care of this headache..one thing after another with this car lol
  4. Jodi
    Jodi Veteran Member
    222
    129
    May 22, 2019
    You'll be fine...
    I have BBC / TH400 combo on my car and the 4' long cable is just perfect.
    But due to my deep pan design the bracket (as seen from the pic.) needed to be modify for better fitment.
  5. nbfd7
    nbfd7 New Member
    May 11, 2020
    cool thanks for the input..do by chance remember how you routed your cable?..I know they have to be looped just curious what way worked best for you
  6. Jodi
    Jodi Veteran Member
    222
    129
    May 22, 2019
    I looped it "S" shape on top of the transmission.
