Back drive linkage
twozs
8,817
hopewell jct ny
Does the 1970-2 staple shifter have a back drive linkage to operate the neural safety and reverse light ?
Gary S
24,419
I believe that all the Camaros of that vintage except column shift automatics had the backdrive linkage. It would be needed to activate the steering column lock.
twozs
8,817
hopewell jct ny
Does it operate the gear shift indicator or does it also operate the reverse lights and neutral safety on the auto floor shift ?
l16pilot
2,170
Hurlock, MD, USA
I'm pretty sure the column shift autos used the same back drive linkage...just in reverse, meaning instead of the trans lever using the back drive linkage to operate the column, the column used the back drive linkage to operate the trans shift lever.
30,830
^+1
I'm pretty sure you're right!
How else would the gear selection work from the column?
I once had a console shifter cable break on my 78 and I figured out I could operate the transmission gear selection with the steering column collar until I got the cable replaced. ;)
Gary S
24,419
The 1970 Assembly Manual shows the stirrup shifter with a cable that goes to the tranny to shift it and the backdrive linkage is connected at the tranny to run back up to the column. It also shows the neutral safety/backup switch up on the column being driven by the backdrive linkage. I can't find a page showing the linkage to the PRNDL indicator.
twozs
8,817
hopewell jct ny
This is what I thought. The auto switch on the column had 4 wires and the manual had 2 . The neutral safety and reverse had nothing to do with the console area on the staple shifter ? ...
lapedr
667
Pembroke, GA
There is linkage that operates the neutral safety switch on the column on some models, it works the column lock, and it enables the shift indicator wire to show what gear you are in. On early models the neutral safety switch was in the horseshoe shifter, I think that after the strike they changed it to the steering column, I know mine is in the column.
