bad gas in an LS
Discussion in 'High Tech Retrofits' started by Goat, Jun 4, 2021.
  1. John Wright
    15,216
    401
    Aug 9, 2002
    Rustburg, Va
    Do you think the injectors may be acting up? Old gas takes a toll on the injectors.
  2. kdracer73
    kdracer73 Veteran Member
    548
    50
    May 12, 2010
    OC, Ca
    Most obd2 systems allow for bi-directional controls. It is a scan tool/diagnostic tool that communicates with the PCM. It will have functions that allows you to turn on and off different circuits through the computer.
  3. kdracer73
    548
    50
    May 12, 2010
    OC, Ca
    Try disabling the fuel pump/injectors and see if it will run on carb spray. Find a vacuum port and spray carb spray into the intake manifold. It doesn’t take much. If it runs on carb spray the ignition system is working, and you can focus on the fuel issue.
  4. Goat
    1,935
    50
    Jun 7, 2001
    moncure, NC
    badazz81z28 likes this.
  5. Goat
    1,935
    50
    Jun 7, 2001
    moncure, NC
    Thanks for all the replies and suggestions. I will have to set aside a couple of days soon to figure this out. Right now I'm swamped with other projects. I'll post back up when I have some answers...
    badazz81z28 and kdracer73 like this.
  6. 76z28
    76z28 Veteran Member
    2,369
    177
    Jun 29, 2009
    bakersfield
    Same with my fuel injected big block... I didn't even out stabil in and a year and 3 months later it started right up.
  7. streak
    streak New Member
    11
    Apr 27, 2021
    If it's a high compression 440, I've had a number of issues with battery tenders not "tending" so they would crank but not fire or show a status of green but be deader than dead. Personally I've had 50/50 luck with them ruining batteries versus maintaining them over 6 deployments. Never once had an issue with the gas after the multiple 8-15 month trips to the sandbox. But I did always run Stabil through the system so it got into everything. I'd do plugs and battery and go from there. If that doesn't fix it then keep a charger on it if you keep cranking it or soon it will be the battery...
