bad hood springs?
Discussion in 'Body Restoration' started by biggrass, May 26, 2016.
  1. biggrass
    biggrass Veteran Member
    370
    Aug 30, 2006
    GURNEE, IL
    Guys I have a fiberglass l88 hood that will not stay open without a prop rod. I currently have gold colored springs installed. Question is, is there a way to tell if its the springs or the hood hinges that are bad? Also best way to remove springs. These are thicker than stock ones. Tried pulling with a chain and will not budge.
  2. phat80
    phat80 Veteran Member
    1,022
    13
    Jan 4, 2013
    Victoria BC
    what?
    forgive me but I don't understand the question. Don't hood springs just unbolt?
  3. Z27LS3
    Z27LS3 Veteran Member
    840
    Nov 12, 2007
    Pensacola FL
    would'nt a fiberglass hood be lighter than stock? pics would help so we can see what you have. I, in the past, have pryed hood springs off with a large flat tip screwdriver or a prybar. put alot of padding on the fender, painted areas. I used moving blankets to protect the paint. pryed the old ones off and new ones on my old 69 conv SS. the ss hood was heavy and when correct replacement springs were installed the hood seemed to fly open, was worth the effort. sounds like your hood springs need replaced.
  4. Zspoiler
    Zspoiler Veteran Member
    3,779
    365
    May 6, 2012
    Federal Way, Washington
    You probably have the original hood springs.Those are fine for steel hoods.But for fiberglass hoods,you need to use the springs supplied by them.Because fiberglass are lighter .For instance I have a Glastek cowl hood on my Camaro and use their springs .Because they already know what springs to use.
  5. MotionClone
    MotionClone Veteran Member
    1,479
    301
    Jan 20, 2014
    away from the crazies
    I have a glass L-88 with the lighter gold springs too. I had some trouble with them keeping the hood open so I made a little extension for the ends to put a little more tension on the spring. If yours needs a prop rod then maybe your hinges are binding? or maybe those springs just arent heavy enough.
  6. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    Take apart some clothespins and jam the wooden pieces in between the coils while the spring is extended (when the hood is lowered as much as possible).
    Raise the hood and you should have the spring extended enough to unhook it from the hinge.
  7. Twisted_Metal
    28,457
    1,778
    Hinges won't let the hood drop... It's the springs.
    MotionClone found a good solution without hunting for different ones.:D
  8. phat80
    1,022
    13
    Jan 4, 2013
    Victoria BC
    hey
    I still don't get it. What's the problem? How can you not get your springs off?
  9. biggrass
    370
    Aug 30, 2006
    GURNEE, IL
  10. biggrass
    370
    Aug 30, 2006
    GURNEE, IL
    Guys these are the springs that were installed by the shop when the hood was installed. I did go to vfn fiberglass locally and purchased gray colored springs that they say will work. I have pulled and pulled and no luck.
