Battery Draw
Discussion in 'Electrical Systems' started by 2000z, Nov 28, 2020.
  1. 2000z
    2000z Member
    72
    12
    Sep 18, 2005
    Tulsa, OK
    I've been trying to track down a 280 miliamp draw on my battery. With the multimeter between the negative battery cable and the battery post I pulled every fuse in the car and the draw never went away. I unplugged the the 2 pin connector on the alternator and the draw went away. It should be noted that I just replaced the alternator and the one I replaced was in the car less than a year and died. Any idea what would be causing this?
  2. badazz81z28
    20,549
    1,380
    Alabama
    When the engine is cool....is the alternator warm?
  3. tom3
    tom3 Veteran Member
    13,388
    982
    Aug 1, 1999
    ohio
    This car have an amp gauge or a "gen" light?
  4. 73 Z
    1,159
    73
    Jun 9, 2007
    Los Angeles, Ca
    You've narrowed the problem, must be between alt or wires to alt circuit/gauge
  5. Twisted_Metal
    29,492
    2,389
    Sounds like a faulty diode in the alternator is causing the draw.
  6. carhead22000
    carhead22000 oldblue
    471
    187
    Sep 5, 2011
    canada
    alternator.
  7. CorkyE
    11,280
    863
    Agree with Twisted. You can buy rebuild kits and YouTube has several videos on how to install.
  8. mallard
    mallard Veteran Member
    1,152
    342
    Oct 3, 2013
    SK, Canada
    My guess as well.
  9. 2000z
    2000z Member
    72
    12
    Sep 18, 2005
    Tulsa, OK
    I found the problem and it wasn't the new alternator. Looks like the previous owner half assed a 1 wire alternator install and then swapped the 3 wire back in before selling the car. I recently cleaned up the wiring in the car and one of the wires for the 2 pin connector on the alternator was mangled inside the electrical tape around the wires. I replaced that wire and once that connection was good again that plug was getting 12V straight from the battery. I pulled all this wiring and I am going back with a new 100 amp 1 wire alternator with a new wire. Since I also went EFI the 100 amp alternator is probably a better idea over the stock replacement 63 amp from the parts store.
  10. a73camaro
    a73camaro Veteran Member
    1,068
    Oct 22, 2000
    Denver, CO
    You can remove the positive wire from the alternator and confirm that the draw goes away.
