Bellhousing Dowl Pins
Discussion in 'High Tech Retrofits' started by badazz81z28, May 10, 2017.
  1. badazz81z28
    19,196
    1,083
    Alabama
    I'm looking for longer dowel pins for my Engine swap and I need .621 and it seems they are all .625? What are you all using for LS engines?
    Also...does anyone have opinions as to using off-set dowels? Is it the bell housings that are off or is it the blocks?
    I remember my LS1 needing .007" off-sets with the TKO and swapping bell housings yielded me needing .014" for the T56...
  2. Zspoiler
    Zspoiler Veteran Member
    3,778
    364
    May 6, 2012
    Federal Way, Washington
    Have you Checked with the bell housing manufacturer. Or Scatter shield manufacturers like Lakewood.
  3. BonzoHansen
    20,303
    1,560
    Jun 1, 2005
    Scott from Hamilton, NJ
    try robbmc
    or call jody @ jody's tranmissions
  4. Goat
    1,919
    46
    Jun 7, 2001
    moncure, NC
    "Also...does anyone have opinions as to using off-set dowels? Is it the bell housings that are off or is it the blocks?" It can be either. Doesn't really matter which one it is because each one is relative to the other. There is no reference point except the crankshaft centerline which as you know, needs to be as concentric as possible to the BH. The block can cause this misalignment or the BH, or both - doesn't matter really...
  5. badazz81z28
    19,196
    1,083
    Alabama
    ^^ Im being lazy...I'm swapping in my LS7 and I don't "want" to take the face of the T56 off again....which drives other maintenance....clutch hydraulics removal and bleeds, driveshaft removal etc...
  6. Goat
    1,919
    46
    Jun 7, 2001
    moncure, NC
    What's up with a .621" dowel pin? Is that the standard size in your block or is that what you measured?
  7. Bandit723
    Bandit723 Veteran Member
    3,384
    530
    Oct 1, 2016
    Waupaca WI
    Summit has the .621 if that is what you need. list them for an LS. Competition Products has the offset ones as well.
    http://www.competitionproducts.com/Transmission-Dowels/products/1298/
    https://www.summitracing.com/parts/nal-1453658
  8. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    For my swap I bought .625 .007 offset pins (standard chevy) and sanded them down, your only talking .004 to bring the one end to size it doesn't take long. There is a company that will sell you offset pins for an LS swap for 40 bucks, but that was more than I was willing to spend for such a minor modification. Everything worked great and I was able to dial in my bell to .002 overall.
