Just spinning the oil pump drive rod will not work, when dist is installed it seals the oil gallery, use a tool like this:Priming with the oil pump via the distributor shaft makes sense.
Thanks
Thanks
One thing I dont see mentioned is the original stamped rockers are self-aligning. If the new roller rockers are self-aligning, using them with guide plates can create a bind. If the guide plates push the rocker sideways to the point where the alignment lip of the rocker ends up on the valve stem tip, that's a huge bind that will bend a pushrod.I had regular stamped rockers and I put these 1.5 ratio full roller rockers. They are speedmaster brand. They are cheap,but looked pretty decent.
For sure. Guide plates are not just bolt on and go. The mounting holes are somewhat oblong to allow for some adjustment. I'm using adjustable ones that allow you to independently align the intake and exhaust pushrods. Takes time, but it works out well. Probably not needed on vortec heads since the valves arent weirdly offset.This is a good point, however, the roller rockers I have do not have self alignment but one thing I missed is adjust the alignment plates properly as this is not too critical for the stamped rockers with self alignment but it is critical for the roller rockers. The #1 cylinder rockers do not look square and I think that caused the issue. I was watching videos last night and saw how the builder was putting effort aligning the end cylinders.
your using guide plates with stamped self alignment rockers?This is a good point, however, the roller rockers I have do not have self alignment but one thing I missed is adjust the alignment plates properly as this is not too critical for the stamped rockers with self alignment but it is critical for the roller rockers. The #1 cylinder rockers do not look square and I think that caused the issue. I was watching videos last night and saw how the builder was putting effort aligning the end cylinders.
