Bent Trunk Lid
Discussion in 'Body Restoration' started by badazz81z28, Aug 1, 2020.
  1. badazz81z28
    18,226
    853
    Alabama
    35616A49-8EB0-42C2-BE65-57F10C54F4F7.jpeg 2079BD6B-0B93-443A-927C-774A5AA474E4.jpeg So from what I can tell, my trunk lid is more bowed on the passenger side versus the driver side. I had another trunk lid a few years back and it wasn’t flat either. This bow makes it so the trunk lid doesn’t sit very flush at all with the 1/4. What have y’all seen?
    hubedobeedo likes this.
  2. djorgensen3
    djorgensen3 Veteran Member
    585
    88
    Oct 15, 2009
    Peoria, Az
    Both of my trunk lids are that way as well. There is also a bow to them from side to side along the rear of the trunk lid.
  3. badazz81z28
    18,226
    853
    Alabama
    @djorgensen3
    The bow is only on the pass side like mine? Mind you, this is after I gave it some 2x4 action....
  4. giggity
    giggity Veteran Member
    1,245
    223
    Mar 18, 2013
    Pearland, texas
    both my stock ones are off. I dont think they were ever perfect.
  5. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,130
    80
    Nov 7, 2002
    New York, NY
    they where never perfect even from the factory. it is what it is,just got to deal with it
  6. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,370
    89
    Jan 1, 2005
    Schererville,In.46375
    How’s the contour to the top of the quarter panel ?
  7. badazz81z28
    18,226
    853
    Alabama
    I would like to see more pics then. I don’t think this is normal. None of my previous 2nd gens had such a bow. The trunk doesn’t even seal on that side.
  8. hubedobeedo
    hubedobeedo 3rd times a charm
    551
    186
    Jul 18, 2013
    Huntertown,IN
    worked on them when they were new make the outside fit 1/4's .to seal you will have to adjust the seal part of jamb,sounds crazy but if you can someboby inside when shut and find low areas. or what you can do with out seal installed is take clay balls and place on all perimeter points and go from there. what we used to do back in the day was to take masking paper and go around trunk lid when shut and adjust jamb as needed. if you take a piece of 2x4 and tap up from bottom of jamb ,take you time . good times o ye by the way this is a original 71 GM deck lid off different car that i bought and came to me with all edges bent to f! got part credited told guy i would pay ship because it was so clean i have probably 45 hr.s straightening it so that filler would be mostly primer
  9. badazz81z28
    18,226
    853
    Alabama
    You fixed the bow? Mine doesn’t match the quarter on the passenger side like yours. I certainly would like to get another lid to see the results.
  10. 80sz
    80sz Veteran Member
    3,376
    490
    Feb 2, 2014
    Buffalo,n.y.
    I had issues with the bow being different on multiple lids also. I picked the closest one to one I had
