Can anyone confirm that this style of drop base will fit a Holley 4160 / 600cfm w/ electric choke ? Often referred to as the L88 or LT-1base
TAZZ 1 IF the engine I am working on wasn't already equipped with a square flange Vortec intake manifold I would definitely consider using a Q-Jet.Give me a good Q-jet all day long for any street motor with less the 400 hp
I’m 95% sure I had that L88 fitted on a Holley 600 VS w/EC.
Here’s a pick of it on an original 3310 VS with complete manual choke, lots of room in that area, I’m sure you will have room, maybe a dimple would be needed at the most.
I have one on my 4150 with elec choke. Mine came with a breather tube under the base to vent the pcv. I carefully removed that and welded a cap on the hole. If I remember correctly, I also had to make a minor mod to the mounting flange as it comes with a small locating notch on it which fits whatever original carb the base was made for.Can anyone confirm that this style of drop base will fit a Holley 4160 / 600cfm w/ electric choke ? Often referred to as the L88 or LT-1base
Still using the stock 1981 Z28 hood. I had taken the cowl induction sealing ring off the underside when I was using a different drop base, but with the current base, I have plenty of room and could probably put it back on.biker, with the above mentioned parts, what hood is on your Camaro and did you have to notch or dimple the underside of it ?
thanks
