Best carburator for 454?
Discussion in 'High Performance Modifications' started by jemeah, Jan 27, 2009.
  1. jemeah
    jemeah New Member
    26
    Sep 19, 2007
    IstanbuL /Turkey
    i have 454 chevy engine in my 74 camaro..There is edelbrock q-jet carburator but i want to change my carburator for best performance which carburator holey or edelbrock and 650 cfm or 750 cfm can i use?
  2. zach133
    zach133 Member
    32
    Jan 25, 2009
    arlington, tx
    with my experience you really cant go wrong with the classic holley 750 cfm double pumper.
  3. mjoc
    mjoc Veteran Member
    3,534
    Apr 29, 2003
    Sherman Oaks, Ca
    for a 454 I would go with atleast an 850 or larger. I have a buick with a 455 stage 1 and it is basically stock I am running a 850 cfm DP. and I think it needs a little more CFM.
    Mike
  4. bbc nova
    bbc nova Veteran Member
    1,124
    Apr 18, 2007
    MN
    If its anywhere close to stock the 750 will be fine.
    I have an 800 on my 496 and it makes 580 hp and 590 tq.
  5. Cardinal
    8,342
    66
    Jun 22, 2003
    Endicott, NY
    Depending on your cam, gears, trans, converter, etc. I'll bet that the money you spend on a Holley will be wasted and there will be NO gain in replacing the Q-Jet.
  6. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
    Keep the q-jet. For some reason people think that q-jets are bad b/c they are a stock piece. I dont know much about the eddy q-jets, but I am sure it they are the same as the rochester.
    The rochester q-jets are one of the best carbs out there.
  7. rscamaro73
    rscamaro73 Administrator Staff Member
    14,977
    17
    May 30, 1999
    Striking fear and destroying the enemy
    + 1
    I put one on there, then figured out some things I needed to make it better....changed some stuff and I was in bidnez :)
    secret is knowing HOW to tune them....and what your engine needs...
