Best gears for street?
Discussion in 'Transmission & Driveline Topics' started by ratpatrol71z28, May 11, 2013.
  1. ratpatrol71z28
    ratpatrol71z28 Veteran Member
    1,577
    Mar 29, 2012
    Mantweeka, California
    :bowtie: So I am going to look into my rear end and try to find out what gears are in it. What is the best gears for a mainly street driven camaro and a little highway useage?
  2. 3504SPD
    3504SPD Veteran Member
    590
    Jan 30, 2011
    Central Valley California
    I've always liked 3:42 gears.
    Double J likes this.
  3. muscl car
    23,233
    1,673
    Jul 8, 2001
    SoCal High Desert
    if it's mainly street and no freeway usage then go with a 4.10 or 4.56 rear gear , that would be a fun gear with neck snapping acceleration
  4. ratpatrol71z28
    1,577
    Mar 29, 2012
    What would 410 RPMs be at going around 60-70?
  5. Marks71BB
    11,834
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    3.73 or 3.42 but a lot of factors to consider, transmission and powerband specifically.
    I would NOT recommend a 4.10 or 4.56 unless you have real tall tires and NEVER get on the freeway for more than a couple miles or have an O.D. transmission.
  6. ratpatrol71z28
    1,577
    Mar 29, 2012
    Okay, thanks for the advice..... I usually run 275-60-15s in the back...
  7. Marks71BB
    11,834
    Aug 25, 2002
  8. ratpatrol71z28
    1,577
    Mar 29, 2012
    Is there any posssible way for me to ceck my rear end to see what kind of gears are in it?
  9. theflash
    11,044
    36
    Feb 27, 2004
    Podunk, CT
    Easily, pull the cover off,
    I like a 3.73 for a street strip application with a 28" tall tire, like the ones you have.
    Itsadryheat79 likes this.
  10. muscl car
    23,233
    1,673
    Jul 8, 2001
    SoCal High Desert
    just input tire size which is 28" transmission gear ration which is 1.1 and then gear ratio choices and this will tell you your rpm/mph for ea gear selection
    http://www.wallaceracing.com/gear-speed.php
    3k rpm at 60mph ...
    3.42 ... 66.43 MPH
    3.73 ... 60.91 MPH
    4.10 ... 55.41 MPH
