best way to clean old bolts
Discussion in 'Body Restoration' started by giggity, Oct 15, 2020.
  1. simso
    simso Veteran Member
    497
    59
    Jul 10, 1999
    Australia Perth WA
    Yep been here done that, i have used the caswell black oxide kit as well, they looked great but rusted up again pretty quickly.
    best i have found so far, blast them clean with an oxide grit, takes seconds to blast a bolt clean, then push them into a piece of cardboard and spray the heads topside and underside with some black epoxy primer.
    this is a photo of some bolts before and after cold oxide treatment, wouldnt recommend the procees now, epoxy primer is the way to go
    https://nastyz28.com/threads/simso’s-78-rust-resto-rebuild.322687/page-5
    And the simple setup used to blast and oxide coat the bolts
    https://nastyz28.com/threads/simso’s-78-rust-resto-rebuild.322687/page-7
    KingofThings likes this.
  2. Rustles
    Rustles New Member
    20
    15
    Sep 24, 2018
    I would add a word of caution concerning bolts that will need to be torqued. Not that every bolt shouldn't be torqued but any critical bolt that needs to be torqued you should be aware of the dry versus lubricated torque tables and that ANY change to the threads might change your ability to get a good reading. My guiding principle is to buy new for any bolt that I deem critical or for other "custom" bolts that aren't easily sourced to be very gentle with the threads - generally solvent and a brass wheel. I prefer the POR products for painting the heads but agree that it can be tedious..
  3. Luwi67
    Luwi67 New Member
    Aug 1, 2014
    Long Island, NY
    It's also important to use a thread restoring die instead of a thread cutting die to clean the threads. Thread restoring die will reshape the damaged threads while a thread cutting die will shear off material from out of shape threads and leave a loose fit.
  4. DennisG
    DennisG New Member
    24
    Dec 26, 2016
    1 Ordinary bolts are not expensive if you buy them by weight
    2 If your concern is rusting, consider heated storage
    3 if you must use a wire wheel hold the bolt securely in vise grip pliers
    4 If the bolts are rusty, isn't the car sheet metal also rusty?
  5. Bandit723
    Bandit723 Veteran Member
    3,384
    530
    Oct 1, 2016
    Waupaca WI
    well i can tell you that 5% vinegar takes forever to get the rust off....
  6. Rustles
    Rustles New Member
    20
    15
    Sep 24, 2018
    Thanks - I forgot to mention the die vs. thread restorer - good point
  7. Revin
    Revin Veteran Member
    599
    106
    Aug 31, 2016
    Round Rock , TEXAS
    WHAT!!!
    We are suppose to clean the screws of rust???
    That is OEM original equipment, numbers matching RUST!!!
    I could sell it! LOL
    Wonder how much 1973 rust is worth...
    OFLHLG likes this.
  8. OFLHLG
    OFLHLG New Member
    17
    Aug 29, 2010
    Finksburg, md
    I have always just wire-wheeled mine.... doesn’t hurt the threads and cleans them up great. Just put a mild wire wheel on a bench grinder. You can hold a bolt in your hand and move it all around different ways to clean it or you can hold it with a pair pliers but you do have to be careful but this method has worked well for me
    KingofThings and giggity like this.
  9. giggity
    giggity Veteran Member
    1,340
    276
    Mar 18, 2013
    Pearland, texas
    Not rusted , just surface rust, and not clean. I powder coated and painted almost everything going back on, not leaving cruddy, rusty, looking bolts on there. Id kick my own ass if I saw that every time I opened the hood.
  10. diablonut59
    diablonut59 Member
    48
    Aug 9, 2013
    detroit, michigan
