best way to clean old bolts
Discussion in 'Body Restoration' started by giggity, Oct 15, 2020.
  1. dcozzi
    dcozzi Veteran Member
    3,834
    902
    May 1, 2002
    Phoenix, AZ
    Soak them for a day in Simple Green. Swish 'em around and rinse off.
    Put a cheapo steel Goodwill tray in a plastic bucket do the baking soda and water, battery charger trick for another day. Presto! Clean non rusted nuts, bolts and washers for a couple bucks.
    There are a lot of ways to do it if you are not in a hurry. If you are, buy a tumbler but, you still wait overnight and grease your walnut shells in the process.
    KingofThings likes this.
  2. Mr. Morgan
    Mr. Morgan New Member
    Jun 6, 2019
    Just curious what other people have done. Its not a restoration situation, so doesnt have to be perfect, I just want the bolts to look good.[/QUOTE]
    This an expensive option. But if this is the sort of thing you'll do for a long time. Then its worth while. You can get a tumbler. Any kind im sure works great. A model I was looking into is made by Eastwood. https://www.eastwood.com/eastwood-5-lb-tumbler-with-media.html
    They range from 100 to 250 dollars. Im sure you can find cheaper. But this looks like a great way to get rust off bolts and polish them like new overnight.
    KingofThings and giggity like this.
  3. Bandit723
    Bandit723 Veteran Member
    3,384
    530
    Oct 1, 2016
    Waupaca WI
    They range from 100 to 250 dollars. Im sure you can find cheaper. But this looks like a great way to get rust off bolts and polish them like new overnight.[/QUOTE]
    Looks like they use some type of green media to get these cleaned up. To save folks the hassle cat litter does not work.
  4. giggity
    giggity Veteran Member
    1,340
    276
    Mar 18, 2013
    Pearland, texas
    this was cool to watch! I remember doing this in high school chemistry class 30 years ago!!
    KingofThings and Bandit723 like this.
  5. 76 camaro car 1
    76 camaro car 1 Veteran Member
    2,430
    24
    Apr 23, 2010
    St.Augustine,Florida
    SEM trim black is some good stuff. I have used it for years.
  6. Twisted_Metal
    28,464
    1,780
    SEM trim black is great paint but I'm pretty sure I actually used the SEM self etching primer on the bolt heads. (Not paint)
    I DID use SEM trim black on my grill and rocker panels and it's held up better than I ever expected (for over ten years) on those exterior parts.
  7. KingofThings
    KingofThings Veteran Member
    152
    38
    May 8, 2020
    Is that the name of the product or simply a contraction of the name?
  8. Twisted_Metal
    28,464
    1,780
    SEM is a company name.
    They make quite a few automotive paint products including interior "dyes".
    SEM Self Etching Primer (Black) #39673 (It has an acid content is very nasty smelling stuff.)
    SEM Trim Black #39143
  9. KingofThings
    152
    38
    May 8, 2020
    Ok thank you. :)
  10. Revin
    Revin Veteran Member
    599
    106
    Aug 31, 2016
    Round Rock , TEXAS
    The tumbler works GREAT!!
    Takes a while but good job!
