best way to clean old bolts
Discussion in 'Body Restoration' started by giggity, Oct 15, 2020.
  1. KingofThings
    KingofThings Veteran Member
    152
    38
    May 8, 2020
    Meant to add that I only tumble sets of things from specific areas, such as a fender, together. When done they go right back in their zip bag for paint later.
    giggity likes this.
  2. Rosster
    Rosster Veteran Member Gold Member
    214
    100
    Mar 1, 2020
    Pics please before and after!
    KingofThings likes this.
  3. 2ndOwner78
    2ndOwner78 Member
    48
    23
    Nov 6, 2014
    Minneapolis, MN
    And after they are cleaned..........
  4. giggity
    giggity Veteran Member
    1,340
    276
    Mar 18, 2013
    Pearland, texas
    first try using what I have.
    I hit the bolts with wire wheel, and then soaked in T9. This was just a test. Seems to have cleaned them up pretty good, not sure about long term. pretty sure this stuff can wear off.
  5. Canadian Barton
    Canadian Barton Veteran Member
    277
    89
    Jul 20, 2015
    Alberta
    WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
    HOGDADDY, Peck, giggity and 1 other person like this.
  6. KingofThings
    152
    38
    May 8, 2020
    Partly why I heave them into the tumblers to have them do all the dirty work. :)
    giggity and TommyRS70 like this.
  7. Twisted_Metal
    28,464
    1,781
    But the wire wheel takes off all the paint, rust and/or greasy stuff so all you have to do is wipe the spider webs off. (When you finally find them.) ;)
    Canadian Barton and KingofThings like this.
  8. TommyRS70
    TommyRS70 Veteran Member
    1,288
    146
    Jan 31, 2004
    KY
    If the manganese phosphate finish is still good, Boeshield works well. Parkerizing tumbled bolts brings them back to like new, if not pitted.
  9. KingofThings
    152
    38
    May 8, 2020
    Hadn’t heard the term Parkerizing before, thanks!
