big block Chevy breather mess
Discussion in 'Engine Topic' started by jake1992jake, Jun 10, 2015.
  1. jake1992jake
    jake1992jake Veteran Member
    132
    Aug 22, 2010
    neshkoro wi
    Drove car too work on interstate 50 miles it runs about 3k on highway. I have oil all over valve covers and fire wall I just have 2 breathers. One on left and right. Any suggestions on too fix this? Pvc valve necessary? If I run breathers with hoses too a canister will that clear the mess up..
  2. JWZ28
    JWZ28 Veteran Member
    1,239
    Feb 27, 2011
    Alabama
    Ive tried running two breathers and two breathers to a catch canister on my warmed over 350 and neither relieved enough crank case pressure. PCV on one side and a breather on the other cured it right up.
  3. jake1992jake
    132
    Aug 22, 2010
    neshkoro wi
    Does it matter which valve cover. I usually run it on drivers side
  4. Damon
    Damon Veteran Member
    12,939
    24
    Nov 16, 2000
    Philly area
    Doesn't matter which side, but do you have baffled valve covers?
  5. ssenay72
    ssenay72 Veteran Member
    134
    Sep 21, 2012
    Leominster, MA
    If your having that much blow by, something might be wrong in the motor, but lets assume its ok. I had " dribble " out of my 540 bb so I switch to bolt a bolt on breather and a bolt on pcv valve and run catch cans. Highly suggest this, you'll never spray oil again.
    I used jegs bolt on breather with their catch cans and for a pcv I think I used billet specialties and used a quick fuel breather retainer for that. Ill dig up some pics if your interested.
  6. muscl car
    23,345
    1,789
    Jul 8, 2001
    Hendersonville Tennessee
    Sbc and bbc have always seen oil sweating from breathers that I know of since the 70's . Simple fix is a sweat band around ea breather and then remove and clean when they become soaked
  7. Cuzz
    Cuzz Member
    66
    Apr 19, 2015
    Michigan
    Im interested in seeing the pictures too.. I have a BBC 496 with 2 breathers and they both blow a little smoke while sitting at a light.
  8. lumpy12
    lumpy12 Veteran Member Lifetime Gold Member
    727
    17
    Sep 16, 2012
    NorCal
    I run a breather on one VC and a PCV on the other that draws through an air-oil separator
    No more venting in the engine compartment and my exhaust smells better!
    tim
  9. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    Necessary? I wouldn't say necessary but as you've discovered you need some kind of crankcase vapor control system. Assuming that the engine is in good shape a PVC system is a simple system with no performance penalty and a great way to go for most street cars. I'd start with that. The valve goes in one cover and vent the other.
  10. JWZ28
    1,239
    Feb 27, 2011
    Alabama
    Does that can vent or breathe? I tried a similar setup with an unvented catch can and it wasn't relieving enough crankcase pressure and was blowing oil out around the base of the dipstick tube.
    EDIT: I see now where you have a breather on the other side? Do you have a pic?
