billet hood hinges
Discussion in 'Body Restoration' started by harleymac, Oct 29, 2012.
  1. harleymac
    harleymac Veteran Member Lifetime Gold Member
    125
    Oct 9, 2010
    decatur il
    im so tired of fighting my hood who has the billet hinges and do ya love them ????
  2. americanhandy
    americanhandy Member
    96
    Feb 19, 2011
    western NY
    got mine @ Eddy Motor Sports and I love them
  3. SMCZ28
    SMCZ28 Veteran Member
    818
    Jun 15, 2010
    United States
    What do you mean fighting your hood 0.o
  4. harleymac
    125
    Oct 9, 2010
    decatur il
    old hinges worn out new hinges way to tight hood doesn't close down in the rear all the way without pushing the back of it down
  5. SMCZ28
    818
    Jun 15, 2010
    United States
    Ah okay, thought you mean it was hard to open and close, had that problem for a while just to lazy to spray it with lube, smooth as glass now. :D
  6. harleymac
    125
    Oct 9, 2010
    decatur il
    have lubed and lubed but these new one will not loosen up so im thinking billet
  7. david.carlton@s
    [email protected] Veteran Member
    1,078
    Sep 1, 2009
    CA
    Did you try raising the hinge in the front slot in order to lower the rear when it's closed? Not intuitive but it works. There are a few threads on Nasty.
  8. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,562
    19
    Jun 14, 2006
    PA - Southeast, bottom of the bubble.
    Details on billet hinges?
    EDIT - $550... ouch.
  9. MikeDVC
    MikeDVC Veteran Member Gold Member
    776
    Jun 26, 2006
    Severn, MD
    I have them; the hood seems to open higher (not sure if this is much of an advantage), they do operate smoothly, and look nice...but considering the cost I wouldn't highly recommend them. My body shop insisted that they have more adjustment then the factory hinges, that is why I got them.
    If you have a fiberglass or carbon hood, you'll have to spend some time getting the correct gas shocks (strength). We had to test fit at least 3 sets before we got it right. The manufacturer (Fesler) was very helpful with this, but it was time consuming.
  10. BonzoHansen
    20,806
    1,834
    Jun 1, 2005
    Scott from Hamilton, NJ
    Mike, that is good. I have heard complaints about some brands where hoods do not open enough on some models.
