1971CamaroGuy
LS Swapped 1971 Camaro
- Oct 31, 2004
- 3,844
Thanks!
Started putting them on and removed the drivers front shock. A little backstory on this....I carried my car to a alignment shop to get the alignment done. I guess in my hastiness I didn't put the bolts in the drivers front shock? I'll own that if I did...it's possible.
The alignment shop told me that the shock had gotten damaged at some point. Had to be my trip there because I haven't driven the car up to that point.
I told them to go ahead replace it, I finally got around to pulling the one they "installed" out and I kept thinking damn this thing is long and looks weird. Here it is against my bilstein fronts...can anyone spot whats off about it?
It's a freaking rear shock they installed on the front....and a cheap one at that. Needless to say I won't be using them anymore. I had them bleed the brakes too and was missing a lug nut on the rear by the time I got back home.
https://www.amazon.com/Monroe-32112-Monro-Matic-Shock-Absorber/dp/B000COSAEW
